Results 1 to 19 of 19
Thread: Volk Wheels
    Veteran Member Three Rings BoostinonYOU's Avatar
    Apr 03 2006
    02 s4, 08 Thundra, 08 gsxr 1000
    Moorpark, Ca
    Volk Wheels
    I have a question I know our cars bolt pattern is 5 x 112 but will a 5 x 100 or 5 x 114.3 fit ? The reason being im about to drop 3k on wheels and tires, the volk GT-M or volk ce28 both of which i can get on a 35 or 33 offset, and does anyone know what the heck the offset means anyways ? Please help !!__!!
    APR Stage 1 13.0009 @ 105 FULL INTERIOR | 100 OCT RACE GAS
    APR Stage 2+ 12.87. @ 109.10 1.89 60FT. FULL INTERIOR FULL EXHAUST | 93/110 mix
    http://www.youtube.com/watch?v=pCPXI5hMOUI
    I have a faster 1/4 time but no slip, didn't bring my helmet and promptly got kicked off the track w/o time slip :(
    APR | JHM | OZ RACING |
    Senior Member Two Rings KryptoniK01's Avatar
    Nov 27 2006
    B5 S4
    Vancouver BC
    Re: Volk Wheels
    I would try to find something in a 5x112 bolt pattern if I were you. There are adapters out there to go from 5x100 to 5x112 but I've yet to personally see anyone use them. As for offset, the general consensus is 32-35mm for most plus sized set-ups
    Veteran Member Three Rings 2BblkAudis's Avatar
    Feb 15 2007
    San Mateo, CA
    Re: Volk Wheels
    Not sure if you went this route yet, but try to find Volk's Japanese website, they actually list some of their euro fitments. Not all wheels are available in the 5x112, but many are offered in 5x112 with 32-35 mm offsets. If you've been to the US distributors site, Mackin Industries, they only list the import applications.
    Senior Member Two Rings BB2001S4:Tim's Avatar
    Oct 04 2006
    NY/NJ/CT
    Re: Volk Wheels
    the 5 implies the # of bolts (which Im sure we all know) and the 112 is the measurement seen here on the 5 bolt pattern pic
    So if you were to measure from the back of the hole to the center of the 2nd hole on our stock wheels you will get a measurement of 112 mm or about 4.4 inches
    here is a link...
    http://www.adaptitusa.com/index.asp?...on=Custom&ID=4
    Jan 29 2006
    b5 s4 stage 3, 4runner
    livermore
    Re: Volk Wheels
    lots of vw guys use adaptors but they're usually in 25+mm spacer setups. so youd need like a 15 offset wheel to make it right i think
    Oct 04 2006
    NY/NJ/CT
    Re: Volk Wheels
    Quote Originally Posted by S.Line.Power View Post
    Its actually the other way arround...you will need a hight et to make that wheel adapter to work...say a wheel 8.5 inches in width with an et of 50 to make sure the wheel wont poke out too much. The lower the et the more clearence you will have for bigger breaks but the more your wheel stick out from the hub which will stick out the wheel well.
    Forum Moderator Four Rings
    Apr 16 2005
    Pearl City, Hawaii
    Re: Volk Wheels
    Quote Originally Posted by BoostinonYOU View Post
    You still live in Hawaii?
    B5S4/A3S3RS3/Hawaii Forum Moderator - PM Comments/Concerns
    18 Daytona Gray Pearl S3
    00 Laser Red S4 (Sold )
    VAST Performance | BLOUCH | AWE | EvolutionRacewerks | Volk Racing | Vogtland | STaSIS/Alcon | JHM Motorsports | RS4 OEM
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Re: Volk Wheels
    5 x 114.3 wont fit.You will need custom hubs...i.e. take your 4 hubs to a machine shop and have them put in studs in a 114.3mm diameter.This is what Jeremy@Matrix did for my A4 in order to run the Volk SE37K's.
    Apr 03 2006
    Moorpark, Ca
    Re: Volk Wheels
    Quote Originally Posted by Jesse S. View Post
    Technically i do, but im currently in iraq
    Veteran Member Four Rings unknowna4's Avatar
    Oct 06 2005
    Soccer mom car
    South
    Re: Volk Wheels
    Or use raderwerks 14twelve bolts:
    http://www.raderwerks.com/parts_details.cfm?type=9
    Apr 03 2006
    Moorpark, Ca
    Re: Volk Wheels
    come to find out it was a typo on the website, How would 18 x 8 with a +50 offset look ? any issues with this wheel clearance/ poke out ???? Please i know some of you are wizards at this stuff !!__!!
    the wheel is a Volk CE28N 5x112 18x8 +50
    Senior Member Two Rings WingsnHorns's Avatar
    Feb 09 2008
    '00 S4
    Vancouver
    Re: Volk Wheels
    With a +50 offset, you might run into clearance problems like the inner part of the rim might hit suspension parts.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: Volk Wheels
    Quote Originally Posted by Issam@034 View Post
    OR
    http://forums.vwvortex.com/zerothread?id=3618449
    *edit unknowna4 already cited this^ .. my bad*
    Apr 03 2006
    Moorpark, Ca
    Re: Volk Wheels
    what about 18x8 with an offset of 32 or 35 would those be okay ?
    And would a 19x9 with those same offsets be a problem ?
    Oct 04 2006
    NY/NJ/CT
    Re: Volk Wheels
    Here is a wheel offset calculator...
    http://www.1010tires.com/WheelOffsetCalculator.asp
    I think the stock width of the avus is 7.5 with an et of 45....i think
    Registered Member Three Rings ChriS4's Avatar
    Nov 09 2007
    A red one. I hate red.
    Track Whore, CA
    Re: Volk Wheels
    Quote Originally Posted by unknowna4 View Post
    Those look sketchy...
    '00 B5S4 - Sold
    '95 Civic EJ1 - Stolen
    Good USA
    Senior Member Three Rings SilverThing's Avatar
    Dec 26 2007
    cars & stuff
    Long Island, NY
    Thumbs up Re: Volk Wheels
    Quote Originally Posted by BB2001S4:Tim View Post
    You are correct.
    Rides:
    '06 S4 Avant, silver/black w/ alcantara, w/ V8 goodness - new DD (finally back in an S!)
    '07 A4 Avant 2.0TQ S-line & Ti, I-white/black (unicorn?) - w/ APR goodness, old DD, now beach-mobile
    '93 BMW 850ci, FE Red/Black - major garage queen
    Previous:
    '01.5 S4 Avant, Silver/Onyx (Sold...miss it a whole lot )
    '98 BMW 328ic, Cosmos/Grey/Black (Sold...miss this one a whole lot, too)
    Apr 16 2005
    Pearl City, Hawaii
    Re: Volk Wheels
    Ahh.. was wondering what happened to you..
    Who's watching over your S?
    Apr 03 2006
    Moorpark, Ca
    Re: Volk Wheels
    wifey has it in CALI so good tuners can do my stage 19 upgrade !!!!!!!!!!!!!!!!______________!!!!!!!!!!!!!!!!!!
