Results 1 to 9 of 9
    Apr 27 2004
    2018 GTS Cab, 2020 AMG A35, 2021 XC40 PLUS parking lift
    Everything you ever wanted to know about H-sport sway bars (almost!)
    In my plight to determine which H-sports to get, I spoke with Hotchkis directly and obtained some info not necessarily available in the public domain. I'm still uncertain of the difference in stiffness between the OEM bars but finally got the differences between the H-sport rears. Here's the info I've been able to obtain directly from Hotchkis:
    RS4 H-sports
    35mmF and 29mm rear
    Front 60% stiffer/ Rear +235%, and +305% stiffer than OEM
    90% stiffer than S4 H-sport rear
    S4 H-Sports
    35mm front and 24mm rear
    Front 60% stiffer/ Rear +145% & 215% stiffer than pre-2007 OEM (2007+ come with RS4 rear)
    30% stiffer than A4 H-sport rear
    A4 H-sports
    35 mm front and 22 mm rear
    Front: +60% stiffer/ Rear: +120% & +150% stiffer than OEM
    Now wouldn't a GB on these be great ??
    Need a hotel in Ottawa? Try Albert@Bay or Best Western Plus Ottawa Downtown
    PM me for AZ discounts !
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Previous rides: B5 A4, B6 A4 Avant, B7 S4 Avant, B7 RS4, TTS, B8 A4, S3, 2019 Targa
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    Re: Everything you ever wanted to know about H-sport sway bars (almost!)
    so, you're planning to get both the front and rear? I was thinking of getting just the rear. I hear the rear takes the understeer out, but the front one puts it back in.
    I'm just confused on which to buy. Can I get them separately? I know if I buy the set, it'll be a lot cheaper.
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Apr 27 2004
    Quote Originally Posted by channad View Post
    Yup, I'll be getting the RS4 set - they're backordered until the end of the week. You're correct that the rear will "reduce" understeer and the front has the opposite effect; however, the front also provides a nice improvement in turn-in which is what I'm looking for. Also, by getting the 29 mm rear, I expect to have neutral handling (if not a bit of oversteer). I had them on my B6 and the improvement was quite noticeable. The rear is available on its own for approx $220. (PureMS or Tire Rack) but I suggest you consider the set. Worst case scenario, you could always sell your rear bar (OEM RS4) with the H-sport front to an A4 guy which would be a nice upgrade for the lighter 1.8 or 2.0 cars.
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Oct 14 2007
    Mammoth Lakes, Ca
    so you're saying the understeer that you get from the front bar is worth it for the type of turn-in you will recieve.
    Apr 27 2004
    ^ You got it !
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Apr 27 2004
    that and the 29mm RS4 h-sport rear should provide a nice offset to this with a net result of mild oversteer.
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Oct 14 2007
    Mammoth Lakes, Ca
    well, it looks like I'm sold on the set. However, I will wait until I get 3 or 4 track days under my belt. I want to see how the car is in stock form first. Then, and only then will I spend the money to make it better.
    Senior Member Three Rings Mello's Avatar
    Jan 07 2008
    '04 S4, '06 GSXR 1K, '06 Apex
    I was hoping for a group buy as well. This is one of the next mods I want to do.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    i'm looking for the rs4 sway, let me know if your selling it!
