Results 1 to 10 of 10
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Wisconsin
    Interest feeler: True RAM AIR
    If I could develop a ram air set up that utilized a direct path straight into a stock airbox that uses an AWE Style ITG open element filter would there be interest? It would be a permanent mod and would render your passenger side Highbeam inoperable. It would seal up for rain and then simply use the stock air duct. Pricing would be fairly cheap too.
    Interest, comments, horrible idea? I'm half way there....
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    Veteran Member Four Rings S4Per's Avatar
    Feb 17 2004
    2013 Audi S6
    Re: Interest feeler: True RAM AIR
    maybe for the hardcore, but i'd never sign up for something that:
    1. took away stock functionality in the likes of a high beam, and
    2. required manual adjustment for rain / no-rain.
    just my 2 cents.
    2013 Addict::S6 (Build) // UNITED MOTORSPORT by AMD STG III | Milltek DP's and Valvesonic exhaust | 200 CPSI custom cats | AWE intake | Arc's, Helix, Morel's for sound
    2018 Q7 3.0T Prestige | Glacier White Metallic | Titanium Black Optic | Adaptive chassis | Drivers Assistance | Tow | Cold Weather
    Never forgotten:
    2008 Addict::RS4 (Build)
    2002 S4 Stage 3 Tip
    Veteran Member Four Rings AB18's Avatar
    Dec 17 2004
    US
    Im planning on making just a drag setup. Im going to totally take off the airbox, and route tubing right off the mass air flow back to the a custom headlight with a filter on the end. If you wanted to get real hard core, just run a tube off the maf to a hole in the headight and put some screen on the end.
    2001 S4 6sp...has a few goodies...and JHM shifted
    Tons of parts for sale..
    GIAC A box ECU for sale-350shipped.
    http://www.audizine.com/forum/showthread.php?t=170072
    Dec 10 2006
    Wisconsin
    Mine will be in between hardcore and daily driver. It would be as quick as walking to the headlight and pushing in a plug if it were raining/snowing and you would instantly have oem intake again. Pull out the plug and add 50-75% more air instantly.
    Wings
    Carbs
    Titaniums
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Quote Originally Posted by s vier View Post
    How about angling it so that gravity works in the favor of keeping water out?
    Feb 17 2008
    Ottawa Ont.
    ITs been done. Its easier to just pull the headlight on track days.
    Veteran Member Four Rings JMTx86's Avatar
    Oct 03 2005
    Quote Originally Posted by BastardS4 View Post
    +1
    00 b5 s4 Single turbo
    1969 Chevy Nova 396 (Full resto, completed in 2016)
    1969 Chevy Camaro 454 (built 454/th400, body is a work in progress)
    11 Chevy z71 5.3 shop truck (Vortech V2 build in progress)
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    Or why not buy a cheapo a4 HL housing and cut that to smitherienes?
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Dec 10 2006
    Wisconsin
    Quote Originally Posted by tike0rz View Post
    Unfortunetly, there isn't really room or appropriate angles to make that work. A simple plug will put the setup back to "stock mode".
    The prototype is coming out really clean. Unfortunetly, the headlight is not so it still needs some tlc.
    I did it on an extra Ecode I bought from a dishonest seller here who sold me a funked up light with the chrome on the inside coming off. I figured this would be the best light to try it on.
    Wings
    Carbs
    Titaniums
    Dec 10 2006
    Wisconsin
    Well no, not really. It wouldn't be easier to pull a headlight than take 5 seconds to unplug a hole, but I get where you're going with the argument. Running an open element outside of the airbox and pulling a headlight is also very different than running an open element inside an airbox and plumbing only cold air to it whether it is sitting in line at the track or racing down the 1/4 mile.
    I have always steered away from the true open elements that are exposed to the hot engine air. Pulling the headlight gives a blast of air while driving but does little to nothing while idling. You're still going to be sucking in hot air until you get up to speed.
    Please correct me if I'm wrong.
    Wings
    Carbs
    Titaniums
