Results 1 to 4 of 4
    Veteran Member Four Rings A4orce84's Avatar
    Feb 12 2004
    Austin, Texas
    CEL - System Too Lean (P1136)
    Hey Everyone,
    So I've had this CEL for a while (P1136 code) and I've searched and tried a few things to fix it.
    Background:
    99.5 Audi A4 1.8Tizzle, had a busted catalytic converter that gave the same code when it popped out of it's flange. I jerry-rigged it so it would stay connected, and after that the CEL went out. Installed a Labree HFC and a few days later the CEL popped back up.
    Symptoms:
    Car idle's a bit funny when in park/neutral, in drive everything seems fine. My gas mileage has been crap, and sometimes the car hesitates when accelerating WOT.
    Solutions Tried:
    Searching around it seemed that a lot of the "potential" issues were with either the MAF or front-o2 sensor. I cleaned the MAF and replaced the O2 sensor..........all symptoms still persist unfortunately.
    Anyone have any other ideas what it may be? I might break-down and taking it to the local Audi Dealership here since I don't want to keep guessing/buying new parts. Thanks in advance everyone!
    --Asif
    USP CLUB MEMBER #101
    2004 A4 1.8T USP - APR Stage 2+, Mototec Sport Exhaust w/AWE downpipe, Valeo Clutch Kit, 2.0T FSI Coils, EVOMS Diverter Valve, Boosted Intake, B5 S4 Front Brakes, RNS-E + Bluetooth Module, VMR 708s (RS4 Reps), Boost Brothers FMIC, '02 OEM Sport Suspension + B5 Front Perches, PODi, JHM Solid Short Shifter, JHM Solid Linkage Upgrade, and a lot more stuff!
    Oct 25 2006
    '98.5 A4 1.8tqm Sport, '01 MDX
    Oxford, CT
    Re: CEL - System Too Lean (P1136)
    Have you done a throttle body adaptation? Also check for vacuum leaks. Do you have a boost/vac gauge?
    Feb 12 2004
    Austin, Texas
    I do have a boost gauge, vaccum is right where it needs to be. I haven't done a TBA....but I don't think that would account for such horrible gas mileage...
    Feb 12 2004
    Austin, Texas
    bump
