Results 1 to 7 of 7
    Veteran Member Three Rings windyctyaudi's Avatar
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    CEL= P0011 "A camshaft position (bank 1) timing over advanced"
    Went to clear my cat CEL today and i got this code as well. what would cause it?? I'm going to clear it and see if it comes back.
    How bad is this code? Can i Drive my car??
    The car runs fine except the white smoke from the exhaust i haven't fixed yet because i dont know what is causing it, but im going to try and do my compression test today.
    My mods now are GIAC chip, HFC and borla cat back
    Veteran Member Four Rings quat's Avatar
    Apr 06 2007
    A4 Quattro 1.8T, H-D VRSCA
    Pittsburgh
    Re: CEL= P0011 "A camshaft position (bank 1) timing over advanced"
    I got this code too after changing my timing belt. I cleared it and it never returned.
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    i only have 51k
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Is the code coming back again and again?
    Your timing belt might have skipped a tooth. Line up your engine to Top Dead Center. Marking on the cam gear line up to the notch in the valve cover, and at the same time the marking on the crank gear line up to the notch on the plate above it. Do not drive the car until this problem is fixed.
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    i received this CEL code when my cam chain tensioner was going bad in my B5 A4. i knew about the problem though, there was a pretty loud rattle under the valve cover because the cam chain was running a bit slack. if the problem is indeed associated with this your cam position sensor might be going bad instead.
    btw if this is what's wrong it is pretty rare, especially for a car located in chicago at 55K miles. a bad cam chain tensioner is frequently found out west in colorado, utah, wyoming, etc where it's really dry climate.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Apr 06 2007
    Pittsburgh
    now why would this code show up in my car when I changed the timing belt? I know everything was lined up properly. But I also know that before I put the belt on the crank moved. I cleared it and like I said it hasn't returned.
    Feb 12 2004
    Everywhere
    This is a common problem when people put on timing belts. You most likely have the timing belt a tooth off... Keep an eye out to see if you get that code again. It take nothing to roll over your timing to TOP DEAD CENTER and check. I feel like I'm preaching to the choir here lately on checking timing...
