Results 1 to 10 of 10
    Veteran Member Four Rings UnkleGatsby's Avatar
    Jan 09 2008
    S8
    Ketchum Idaho
    Porsche Twists on Allroad suggestions?
    Im ready for new shoes. Trying to figure out if i can run 18X9or10 porsche twists. does anybody know if i can run these, and what would you suggest? Offset? Tires?? 19"???
    thanks
    or
    Senior Member Three Rings skiroad'r's Avatar
    Apr 21 2008
    2002 allroad Tip, 2005 Mazda 6 Wagon 5MT
    Central New Jersey
    Re: Porsche Twists on Allroad suggestions?
    9 & 10 inch wide is going to be hard on the allroad. There are some issues of fender clearance and front strut that wide. Keep in mind, your stock offset is between 20-25mm, so 90% of the rims you want will require spacers.
    Personally I don't twists will look good on the allroad, but that's a taste thing. I like choice #2 much better and I love the look of your stealth allroad -- very nice.
    '02 allroad 2.7T Tip
    ASP Flash, 034 Snub Mount (DIY), VAST EFK (DIY), H-SPORTS (Hard)
    Anrott Gen II Front Airsprings (DIY), Magnaflow mufflers with 3.5" tips
    Summers: Yokohama Avid W4S/RS6 Reps
    Fog DRL's, Toggable 628 Relay, Tip Override Recode, Remote Window Recode, Clear Corners (DIY)
    Timing Belt DIY (at 60K miles), Tiptronic Drain & Refill Service DIY (at 62K miles)
    GET OEM PARTS HERE: http://www.europaparts.com/
    Veteran Member Three Rings Alpinevelo's Avatar
    Dec 28 2006
    06 VW Jetta I5 daily driver bone stock 4 now
    Fountain Hills, AZ
    If you are doing Porsche twists and want to avoid having to use adapters you could try set of Hartmann wheels. They have a set with 35mm offset and 5 X 112 8.5 wide...
    http://gallery.hartmannwheels.com/v/audi/new_turbo/
    Now, I thought that AR's had the large front calipers as well and needed 35mm spacing up front???
    It would be interesting to se how they look on an AR...!
    C5 A6 2.7T GIAC software Stage 1, EVOMS DV Valves, Cupra spoiler lip, RS4 OEM 18" Wheels.
    Alex
    Apr 21 2008
    Central New Jersey
    I think you have offset backwards -- lower offset = wheel pushed out to the fender more. To get 35mm wheels to work, you would need at least a 10mm spacer. 17" wheels will clear the calipers (stock wheels are 17x7.5 et 20 or 25 depending on wheel). I've seen people fit 18x9 on the allroad, but it was very very tight.
    Definitely call Hartmann though, they can come up with a correct fitment package for you incl wheels, spacers and longer bolts.
    Dec 28 2006
    Fountain Hills, AZ
    Yup, thanks for clarifying. And I think hartmann has the best wheels and great value as well. Is the group by still going on? Check the group buy forum, Gigi got that started...
    Alex
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    We have the 5x112 twists on sale currently as well, 15mm spacers would be perfect for the allroad.
    If you want to try the 10" Porsche there is a 18x10.0" ET55, with H&R 15mm adapters would put you at 10" ET40 which is about equivalent to an 8.0" wheel with an ET15 offset which should be fine for outside clearance, not sure about inside clearance though. You'd probably want to run a 275-40-18.
    Apr 21 2008
    Central New Jersey
    Pretty sure you'd have a problem on the inside clearance. Others have reported tight fit to front strut with 9.5" wide rims. In the particular case I know of, the wheel had a 35mm offset -- 20mm spacer was very close to outside fender, but workable, same wheel with a 15mm spacer was too close to front strut to run safely.
    Jan 09 2008
    S8
    Ketchum Idaho
    Wow! thank you for all the good info. Im im gonna go with #2 hartmann wether i trade the allroad for an A4 or not.
    Apr 21 2008
    Central New Jersey
    Cool be sure to post pics once they are on -- def want to see how they look.
    Registered Member Two Rings
    Feb 21 2008
    03 Passat 1.8T,08 Speed Triple
    Terre Haute, IN
    I have a set for sale in the classifieds.
    2003 VW Passat 1.8T Manual
    19x8.5" VMR708 RS4 Reps W/ Achilles ATR Sports, Vmaxx Coilovers, Drilled/Slotted Rotors, Badgeless Grille,VG Sharkfin Antenna, Custom 2.5" Turbo Back Exhaust, K&N Filter, Tinted Tails And Side Markers, and Depo Headlights,TurboSmart DV, Skoda Superb Shift Knob/Boot, 15% Tint, 35% Windshield, Alpine CDA-9886, Type-R 10" Sub, MRP-M500 Amp, CompuStar ProSS Alarm
