Results 1 to 9 of 9
    Registered Member Two Rings micdabizzle's Avatar
    Apr 16 2008
    audi a4 b6
    las vegas
    Can Super Charger On 1.8t Or Bi Turbo It??
    i was just thinking about it... i saw a a m3 with supercharger and turbo at the same time... can a4 handle it...
    Senior Member Three Rings BLACKa4QUAT's Avatar
    Mar 26 2008
    union city, ca/fort worth, tx
    Re: Can Super Charger On 1.8t Or Bi Turbo It??
    i lol'ed at the thought until i saw this http://www.forumeter.com/video/28891...ed-Euro-E36-M3
    i dont know if it even runs, or if its just going to blow it self up
    http://www.youtube.com/watch?v=brZ0BYgV9u0&NR=1
    hrmm still i dont think thats a good idea.
    bi turbo would be too much work with a 4 cyl
    easiest thing would be stage 3. if you want power.
    2006 A4 2.0Tqm, S-line, tech, FH-P8000BT, 10" sub, 800 watt,
    VAG-COM mods (remote windows, no chime), revo stg 1 tweaked
    AWE pedals, HRS4 DTMs/Eagle GT, VMR TP
    193.7 awhp/232 ft/lb/91 oct pre-TP
    16MAR09DSWHTAW
    Oct 29 2005
    10speed
    San Francisco, CA
    none of that nonsense, a B.A.T. would cure the need for power
    - Clint
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    people do it a lot on STi's also.. it would work on a 1.8t if you put enough time and money into it. but no one will... and i don't blame them
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Jan 10 2007
    VA
    I'm sure you could super and turbo charge a 1.8T if you had a 1 off custom build with stand alone EMS. Motor would only blow if you ran too much boost. Not worth it though.
    The point of super/turbo charged motors is not to provide huge gains, but a strong powerband with a small motor. Supercharger for off idle and mid range boost...turbo charger for high rpm boost.
    Registered Member Two Rings wifeysaudi's Avatar
    Apr 21 2008
    05 a4 1.8t quattro
    Brigantine NJ
    wow that seems like it would not be worth it.
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    a biturbo on a 1.8T would just suck ass in the turbo lag department unless you had some tiny turbos, like smaller than a k03. you'd be running each turbo off of two cylinders of exhaust flow, which from .9liters of displacement is not much.
    like said above, the turbo/supercharged idea is a good one if you're looking for a great powerband.
    if you're looking to make big power, stroke the block, and throw a big ole turbo on there and pump up the boost.
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    It's been done.
    http://www.europeancarweb.com/18tcha...2ec_challenge/
    Search LarryV on Audiworld.
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    Quote Originally Posted by jungb5s4 View Post
    A parallel twin turbo would, in fact, be rather stupid. I think people are talking about sequential turbos for the 1.8.
    Also, VW has a twincharger on the Euro Golf. Not sure if they plan to bring that stateside though.
