Results 1 to 10 of 10
    Jan 11 2007
    Salt Lake City, Utah
    How much to install rods?
    1. So say the motor is already out of the car and I take it to sombody to have them install the rods and do whatever they need to do, about how much should the labor cost?
    2. I've heard conflicting things about the motor needing to be rebalanced when replacing rods. Some say it's unnecessary, while others say it should be rebalanced anytime you switch out stuff. What's the word?
    3. Do I need to buy any other parts that don't come with the rods purchase? I heard some say rings and other stuff while others mention nothing. 53k mi on the block FYI.
    Forum Moderator Four Rings
    Apr 16 2005
    Pearl City, Hawaii
    Re: How much to install rods?
    A Lot.
    B5S4/A3S3RS3/Hawaii Forum Moderator - PM Comments/Concerns
    18 Daytona Gray Pearl S3
    00 Laser Red S4 (Sold )
    VAST Performance | BLOUCH | AWE | EvolutionRacewerks | Volk Racing | Vogtland | STaSIS/Alcon | JHM Motorsports | RS4 OEM
    Oct 29 2005
    10speed
    San Francisco, CA
    1. A few hundred bux
    2. No
    3. Rings/bearings
    - Clint
    Jan 11 2007
    2. No
    3. Rings/bearings
    Since you said no to #2 (needing the motor rebalanced) I assume your couple hundred bux estimate is just for installing the rods then? How much to rebalance the ish as well?
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    Yeah I got quoted 300 bucks for labor if I brought them the rods and engine on a pallette
    Oct 31 2005
    Ashburn
    I thought when purchasing rods, specfically forged rods that are lighter you need to get the engine balanced?
    - Instagram: @Sinister_rs5-
    Jan 11 2007
    Quote Originally Posted by Boris View Post
    Does that $300 include balancing? Are you getting rings/bearings as well?
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    Hey mike,
    I'm paying 175$ to get it balanced local. This includes the installation time.
    They charged me 25$ per cyl to bore it out to 82.5mm
    You will need ne rod bearings for about 135 $ and trust bearing.
    But once you there have it honed and check out. I would have em dismantle everything hone it and put som new rings and bearings.
    Total should be near 500$
    Balancing with the crank pulley and the clutch assembly is an extra safety for those who want to revv it higher.
    Jan 11 2007
    How high do you think one could rev with rods and stock heads/valves/cams?
    Mar 13 2007
    Montreal
    Max 7500 rpm, cause the weak link is now your valve springs and retainors.
    With springs and retainors, a hair more than 8k
