Results 1 to 10 of 10
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Question Dead Gas Pedal Question
    cant change the title.... by dead pedal I mean dead gas pedal, not the one one next to the clutch...
    So my neighbor has a 2004 A4. He came to me today saying that he gets an occasional dead pedal - press the gas, get nothing. Hes an automatic.
    I asked if the engine rev's, he says it doesnt. If he lets the pedal back up, then down again the car will go. Claims it is worse in hot weather.
    I've been around the a4 scene for a while and thought I knew a decent chunk...never heard of this...
    any clue? pedal sensor or something?
    no codes at all. brought it to the dealer, they couldnt find anything. He had the throttle body replaced on a whim.
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Dec 06 2007
    Re: Dead Pedal Question
    defective Drive by wire system?
    -Kirk
    BetaAlphaTau Member #58
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Throttle body already replaced.....I would assume the the next "logical" thing next is the actual pedal assembly itself that is malfunctioning
    This is a question for diagnosticator
    -Sami-
    Dec 06 2007
    Re: Dead Gas Pedal Question
    Diagnosticator and A4TL especially Old Guy are the Shit!
    -Kirk
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Have him check to see if his brake light switch it malfunctioning.
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Quote Originally Posted by 400HPA4 View Post
    care to explain this one.... i read somewhere about this... but couldnt connect how this could cause dead pedal
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Has to do with the DBW system.
    There is logic in the Engine Control Module that, under certain cirucmstances will not allow throttle when the brakes are applied. A faulty or sticky brake switch is typically the culprit.
    Veteran Member Three Rings Dos::Avants's Avatar
    May 30 2007
    Garage no more :-(
    'sconsin
    Quote Originally Posted by martini View Post
    I believe this is a safety to prevent throttle operation inadvertently while braking, especially while in gear. So, if the ECU is sensing that the pedal is being activated via the faulty switch, then it won't allow the throttle to operate since it is throttle by wire.
    Avanta-Humpa-Lot
    Sep 13 2007
    04 Atlas Grey A4 1.8TQ Avant
    Quebec, Canada
    Aha, felt that once when I wanted to try building boost before being able to accelerate, like race cars do on a restart
    I don't want to hijack the thread, but I'd certainly be interested in knowing if this can be disabled...
    FXK03 - Stasis SS Coilovers - Forge DV - Forge TIP
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by gtimart View Post
    Nope
