Results 1 to 23 of 23
    Apr 27 2004
    2018 GTS Cab, 2020 AMG A35, 2021 XC40 PLUS parking lift
    Anyone interested in an H-sport GB ??
    I had them on my B6 A4 and the benefit to handling is major. Much moreso than a set of coilovers ... I'm planning on getting them for my car but figured I'd see if there's some interest before going through the paces ...
    For info: Click
    I know the set costs $392. out of the US and assume a GB would provide better pricing. Post up your thoughts.
    Thanks !
    Need a hotel in Ottawa? Try Albert@Bay or Best Western Plus Ottawa Downtown
    PM me for AZ discounts !
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Previous rides: B5 A4, B6 A4 Avant, B7 S4 Avant, B7 RS4, TTS, B8 A4, S3, 2019 Targa
    Veteran Member Four Rings hoganalley's Avatar
    Feb 23 2007
    Burlington
    Re: Anyone interested in an H-sport GB ??
    Maybe not in the front bar, but definately in the back. I'd be interested in seeing what's available.....
    05 allroad 2.7T Stock
    99.5 A4 1.8T K04 - Sold
    Dec 01 2007
    Markham, Ontario
    back for me
    Veteran Member Four Rings m5racer's Avatar
    Nov 20 2006
    Quote Originally Posted by evilgabbie View Post
    back for me
    x2
    01.5 A4 1.8t sport
    Apr 27 2004
    Guys, the H-sports are made to be purchased in pairs (front and back) so if you want just the rear then pick up an OEM S4 or RS4 and save some money. The rear H-sport bar is approx. $220. USD versus the OEM being half that ...
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Veteran Member Four Rings ABanT's Avatar
    Aug 07 2007
    B7 ABT Avant
    Would it be odd to run the RS4 Rear sway and an Hsport front sway? I ask because I have the RS4 Rear already.
    Apr 27 2004
    Quote Originally Posted by WhiteABanT View Post
    Firstly all H-sports have the same 35mm front bar. I too have the OEM RS4 bar on my car (comes standard on the 2007 S4). I just spoke to someone at Hotchkis for some feedback on the difference in stiffness between their bars as the only info they provide is the difference between OEM and their bars for each car. I suspect that the H-sport S4 rear bar is similar to the OEM RS4 bar (perhaps a bit softer and stiffer depending on the setting) but their engineering department will confirm this soon. With my OEM bars as well as GT Vogts (stiffer rear springs), I still have some understeer when pushing the car and that's with a 40/60 power split (biased to rear of course). Aside from wanting to improve turn-in I'd like to avoid add'l understeer and ultimately end up with some oversteer.
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Apr 27 2004
    I'm still uncertain of the difference in stiffness between the OEM bars and the 2007+ S4's come with the RS4 rear bar ... Here's the info I've been able to obtain directly from Hotchkis:
    RS4 H-sports
    35mmF and 29mm rear
    Front 60% stiffer/ Rear +235%, and +305% stiffer than OEM
    90% stiffer than S4 H-sport rear
    S4 H-Sports
    35mm front and 24mm rear
    Front 60% stiffer/ Rear +145% & 215% stiffer than OEM (pre 2007)
    30% stiffer than A4 H-sport rear
    A4 H-sports
    35 mm front and 22 mm rear
    Front: +60% stiffer/ Rear: +120% & +150% stiffer than OEM
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Aug 07 2007
    B7 ABT Avant
    So.. you're saying there wouldn't be any benefit to adding the front sway bar?
    I drove a friends S4 Sedan and when I turn it feels effortless, whereas my car
    it feels like I have to battle with the wheel to turn (no not that serious but you get the idea).
    Veteran Member Four Rings Audized's Avatar
    Oct 22 2006
    Eh?
    If you add the front sway, you will make understeering even worse.
    H-sports have hollow-tube design (whereas OEM sways are solid) which makes them stiffer, compared to solid bars of the same diameter.
    Apr 27 2004
    I was actually saying the opposite but some may disagree. The downside to the stiffer front is it adds back some understeer BUT, it also provides better turn-in. In other words, with the stiffer front the steering response feels more immediate and the front end stays flatter around corners. IMO, the improved turn-in outweighs the reduction in oversteer. I'm assuming that the stiffer rear bar is also used.
    Not sure if you're talking about the servotronic steering on the S4 (amount of power assist to steering varies with speed) with quite a nice responsive feel at higher speeds
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Aug 07 2007
    B7 ABT Avant
    I'm definitely looking for a better turn in. Maybe I could take the front if someone only wants the back? I'm thinking it wont be as easy to install as the rear though right?
    On another note, do the Hsport sways come with adjustable end links?
    Apr 27 2004
    I believe the front is a bit tougher to install than the rear. No adjustable end links ...
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Veteran Member Four Rings headshok2002's Avatar
    Jan 22 2005
    2010 VW Passat Highline wagon
    Sudbury, ON
    On my B5... The front was easier than the rear. The rear had subframe reinforcements which were a PITA to install. Front was a piece of cake, though... I'm sure it's the same on the B6? Get both front wheels off the ground, take off the bushings/brackets, undo them from the C-links... voila. It was very straightforward.
    And I went with front and rear on my B5, and was happy I did. Like Steve is saying... turn in is greatly improved, and you'll still have oversteer. The car was completely transformed.
    Apr 27 2004
    ^ Thanks for the info ! Yup, B5 had subframe issues and Neuspeed was one of the manufacturers that had reinforcements as part of the rear bar kit ... To the best of my knowledge none of the sway bar manufacturers offer reinforcements for the B6 or B7.
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Veteran Member Three Rings scorneil's Avatar
    Oct 27 2007
    Oakville, ON, Canada
    PSA - there's a used set in the classifieds, local to Toronto
    http://www.audizine.com/forum/showthread.php?t=205096
    2010 B8 S4 Quartz Gray S-tronic Black Alcantara MMI
    2003 B6 A4 Canvas Beige 1.8T Tiptronic 1+ SOLD
    Jan 22 2005
    Sudbury, ON
    Quote Originally Posted by scorneil View Post
    Ack... buying local... good price... so temped. Must... resist... urge.
    Apr 27 2004
    Quote Originally Posted by headshok2002 View Post
    I believe that set was sold tonight !
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Jan 22 2005
    Sudbury, ON
    Haha well that was quick -- and likely for the best!
    Too bad it wasn't the RS4 kit, or you'd have had an easier solution to your dilemma!
    Apr 27 2004
    No kidding ! I contacted him as I had this crazy idea that I could use the front and try swapping the S4 rear for an RS4 one. BTW, the RS4 set has not been available for very long.
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Mar 25 2008
    Ottawa, ON
    Hey, I just purchased an '04 Avant. I'm interested in getting the S4 set if you get a GB together. Let me know.
    GTA, Canada
    As a heads up, we cannot allow group buys to run unless they are set up and run through an official advertiser. Thanks for understanding.
    RippleChip (Ryan) - Moderator
    Audizine
    01.5 eh4 1.8T || 12 eh5 2.0T
    Apr 27 2004
    Doubt a GB will happen although perhaps a few of us should go in on an order to save on shipping ...
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
