Results 1 to 15 of 15
    Established Member Two Rings enzoballin's Avatar
    Jun 26 2007
    Beverly Hills
    black housing for headlights.??
    ok, so i have seen a couple guys paint the housing on their headlights black and it looks sick! i called audi today and they said that it was preassureized or something like that, and that if i were to paint it then i would have condensation in the headlight cover. What do you guys think? could i paint it and then have them preassureize it? Pictures would be great!
    08 Brilliant BLK A4 Titanium Package Quattro
    GINTANI TUNED
    Veteran Member Four Rings TonyD's Avatar
    Aug 11 2007
    2012 135i tuned+meth'd
    California
    Re: black housing for headlights.??
    You might get some condensation but if you seal it right, you should be perfectly fine.
    Registered Member Three Rings era's Avatar
    Feb 01 2008
    2008 A4 2.0T Quattro TIP
    Brooklyn NYC
    Just make sure to seal it real tight and add some extra sealant if needed. I've opened my headlight twice and no condensation
    - Debadged - Blacked-out RS4 Grille - Prolumen 6000k HID - Llumar 35%/15% - Höen Fogs - CC Mod - VAG'd - Gun Smoked Tails -
    - Blacked-out Housing - VAG'd - CF DTM Style Spoiler - Painted Red Calipers - Red Interior LEDs - Stasis SS CO - Angel eyes -
    About to install:
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    Hundreds of people have done this, and you will get absolutely no condensation so long as you heat up the sealant between the housing/lens so it seals 100% like it was in the first place. Anyone who says, "you WILL get condensation" has never done it or heard of others doing it.
    Here is mine:
    I did this on my Enzo too
    Ignorance is bliss.
    Senior Member Three Rings Bryson's Avatar
    Apr 07 2008
    2006 B7 A4 2.0t (not s-line)
    la quinta, California
    look at mine, no condensation, no need to pressurize, theyre trying to scare you, just make sure you glue em good
    Jan 24 2007
    Wisconsin
    Yup, there is no "pressure" or vacuum in there... You can take out a friggin bulb and look from the back directly into the housing. Complete BS.
    Here is Bryson's thread. He painted the entire housing: http://www.audizine.com/forum/showthread.php?t=202830
    Here is a rough DIY from i3oricua in his thread: http://audizine.com/forum/showthread.php?t=167572
    Here is a rough DIY. It will take basic knowledge and your own critical thinking skills to complete it:
    1. Take off front bumper. Front bumper removal DIY: http://forums.audiworld.com/a4b7/msgs/14104.phtml
    2. Take out headlights
    3. With small flathead, pry off the 6 little metal clips clamping the lens to the housing
    4. With oven/heatgun/hairdryer, heat up the silicone stuff. I stuck a skinny flathead in the silicone and twisted, then went from there to pry the lens from the housing. Be careful not to get any of the stringy, hot silicone anywhere on the housing... and good luck getting it off if you do
    5. It takes a T9 torx driver to remove the plastic strip from the lens, and you're going ot have to PM Bryson or look through his thread to figure out how to remove the plastic on the actual housing if you want to paint the entire thing like he did.
    6. Wipe parts clean, paint properly, let dry overnight probably just in case, reassemble, make sure the silicone gets heated up again when you press the lens back onto the housing so it creates a good seal.
    7.
    8. Profit
    Ignorance is bliss.
    Veteran Member Three Rings 08lichmanj's Avatar
    Nov 18 2006
    PA
    OT but did you tint your ambers Phrost?
    2006 A4 2.0t Quattro 6 Speed
    Tein Basics-20% tint-18x8 Privat Reserv-VMR Testpipe-Revo Tuned Stage 2
    Jan 24 2007
    Wisconsin
    Yup
    Ignorance is bliss.
    Established Member Two Rings m0nk89's Avatar
    Jun 20 2007
    A4 2.0T Q Tip
    Fremont, California
    ACTUALLY, after opening it ~5 times cause of screw-ups, i actually get some condensation in one of my headlights. ive tried using extra sealant but it still fogs up every time i wash :(. just make sure you only open it up once or twice
    2007 A4 2.0T Quattro Tip
    GIAC - Milltek Exhaust - Carbonio Intake - VMR V713 - Stasis Street Sports - RS4 Sway Bar - RS4 Pedals - Angel Eyes/Blacked-Out Headlights - 20% Tint - V995 Hardwired
    Senior Member Three Rings A44sho's Avatar
    Santa Clarita, CALIFORNIA
    I wanna get this done to my car but I don't trust myself to do this. It looks so awesome.
    Jan 24 2007
    Wisconsin
    The first time I did it was to my Mk4 Golf, which is the exact same steps... and I was 16 and those headlights were a lot harder than these A4 ones. Masking off the reflective material with Glad Press n' Seal sucked, but I liked custom painting shit back then
    It will take a first timer a good few hours to complete it, but if you take your time it's not hard at all. You just have to make sure the sealant is hot when you squeeze the lens back on so it seals together, you can't just slap the lens on and hope it closes perfectly. I saw there with my hairdryer for a good 10 minutes per headlight after the clips were back on and they were closed, just to make sure they sealed perfectly.
    Ignorance is bliss.
    Apr 07 2008
    Quote Originally Posted by m0nk89 View Post
    sorry to hear bro, try gasket maker, i did it on mine just to be sure, it dries to a nice rubbery grip. Still no condensation and ive opened my light 10+ times
    Feb 01 2008
    Brooklyn NYC
    Not the best pic, but I've opened up my headlight a second time to black out the rest of the housing besides the reflector parts.
    About to install:
    Established Member Two Rings Strebor04's Avatar
    Dec 17 2007
    Columbus, OH
    Quote Originally Posted by Phrost View Post
    Yup
    did you tint with lamin-x? they look nice!
    2007 Dolphin Gray 2.0 S-line w/Ti Package 20% tint
    Jan 24 2007
    Wisconsin
    Thank you. I used VHT NiteShades. The can looks like this:
    I've never found any store that carries it anymore, and it's getting hard to find. I bought my can from www.summitracing.com and it was about $15 or so after shipping
    Ignorance is bliss.
