Results 1 to 12 of 12
    Active Member Two Rings Corey4.2's Avatar
    Apr 12 2008
    Phoenix AZ
    B7 S4 to RS4 Grill swap
    Okay, the dealership is going to charge me $270.00 to swap out the grill. As I understand it the bumper needs to be taken off. my question is has anyone done this them self and how hard is it to do? How invole would it be to remove the grill and put it back on. Thanks!
    Veteran Member Four Rings FastB7S4's Avatar
    Mar 01 2008
    12 CC Lux Ltd, 11 Touareg, Mk3.5 Cabrio
    ChesCo, Lancaster, PA
    Re: B7 S4 to RS4 Grill swap
    Quote Originally Posted by Corey4.2 View Post
    [O_O]$270 just for labor? Damn! DIY man. Get a friend to help you with the bumper and and you should be good. I don't know how involved it is, but so many people on here have done it so it can't be $270 hard.
    Registered Member Two Rings sprintblues4's Avatar
    Jul 29 2007
    B7 S4
    Bensalem, PA
    It's not to bad, I did mine all lone and it was my first time taking off the front bumper. I think it took me 2 to 2.5 hours from start to finish including putting the car on jack stands. I think the hardest part for me was connecting the washer lines back up while holding the bumper with one hand, if I had a second set of hands it would be even easier. On a scale of 1-5 and 1 being the easiest I would say it's a 2-2.5, just check out some of the DIY forums and you should be good. Save the money and spend it on some mods. Good luck.
    Full Milltek system non res., Vogtland coilovers, H-sport RS4 29mm rear, Huper Optik nano-ceramic tint, 19" OZ Superleggeras, RS4 grill
    Veteran Member Four Rings enigma1406's Avatar
    Sep 17 2006
    2013 S8 | 2006 S4 Widebody | 2014 Q7
    Houston, TX
    This explains how to do it:
    http://www.audiworld.com/tech/ext67.shtml
    The hardest part is getting to the screws labeled A & B in those pictures. Once you've done it a few times you can take off the bumper without removing the wheels. No point in attempting that if you're not comfortable though.
    Veteran Member Four Rings S-Fore's Avatar
    Sep 17 2007
    Very easy. You definately do not need to take off the wheels. I just cranked them and folded back the wheel well cover, used a flashlight and a 6in extension and took the bolts out. I laid out an old blanket and didn't even unhook the washer lines, you do not need to. You can get the bumper off in about 10-15 min. The pics in that "how to" look much more complicated than it really is.
    Veteran Member Three Rings jerrym's Avatar
    Nov 23 2007
    4 Door Saloon
    he probably already went to the stealership
    2009 Mercedes-Benz E63 AMG
    1997 Toyota Supra
    1994 Nissan R32 GTR
    2008 Audi RS4 (gone)
    2005 BMW M3 (gone)
    2003 Mitsubishi Lancer EVO 8 (gone)
    "After a certain point, money is meaningless. It ceases to be the goal. The game is what counts" -Aristotle
    Apr 12 2008
    Phoenix AZ
    Okay, I'm taking the car over to a co-works this weekend and we are going to do the swap.
    Registered Member Two Rings The Broker's Avatar
    Feb 27 2008
    E90 M3 - MK5 Rabbit
    Quote Originally Posted by enigma1406 View Post
    This looks easy and I am glad this post was created because maybe someone can clarify a few things for me.
    How do I get to the bolts labeled C in that link?
    I assume A and B are accessed by removing the fender liner, is that correct?
    Sep 17 2006
    Houston, TX
    Yes. You can get to A & B from inside the fender by removing the liner. C can be seen from the top looking down at the grille. Just stand over the bumper and look down at where C is and you'll see it.
    Feb 27 2008
    E90 M3 - MK5 Rabbit
    Thanks I will try and tackle this on the weekend. The rear bumper was pretty easy to remove so the front shouldn't be that hard.
    Sep 17 2006
    Houston, TX
    Quote Originally Posted by The Broker View Post
    Thanks I will try and taclke this on the weekend. The rear bumper was pretty easy to remove so the front shouldn't be that hard.
    Yes, shouldn't be too hard as long as you have the right tools. And as S-Fore stated, that walkthrough is overkill.
    Veteran Member Four Rings oatzel's Avatar
    Jun 02 2004
    LA
    the tricky part is actually getting it back on and properly aligned
    Current: '14 allroad, Premium +, Sport, Black on Black, H&R c/o, Magnaflow exhaust, Hotchkis swaybars, Neuspeed Gunmetal RSe102, CR-15
    '19 s4, P+, Quantum Grey on Black
    Old: '12 4dr GTI Autobahn, Black on Black
    07 s4 avant, ibis, stasis exhaust, vogtland c/o, h-sport rs4 sways, vmr gunmetal v710s, 50/35% tint
    09 A4 2.0t
    03 a4 3.0qms
    00 1.8TQ
