Results 1 to 6 of 6
    Veteran Member Three Rings johnnybravoa4's Avatar
    Sep 27 2006
    Manchester CT 06040
    Over boost problems
    cars has been running great till last week.. I have been getting spikes up to 30psi and a rough idle after the car warms up. runs fine till it gets up to temp. A little rough nothing to bad, but the spikes up to 30 cant be good. seems to run a little rougher when it get warmer outside. and clues..
    no codes
    I also get a missfire once in a while..
    ARP stage 3+ 2000 A4
    “I don’t go to the gym to get pretty I go to the gym to get pretty big”
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Re: Over boost problems
    I have a similar problem with my car. I am only APR chipped. As its gotten warmer the last two weeks. I started spiking at 20-21, as opposed to the 17 in the winter. Car is misfiring at idle too. I have heard that the plugs I am using Bkr7e's at .028 are not the best for the summer. I might change them out and see what happens. So I was going to ask what plugs you are running?
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Sep 27 2006
    Manchester CT 06040
    I'm running the same plugs but I usually spike to 20 and im not spikeing to 30 so its a little more extream.. Im going to buy a new N75 valve and hope thats the problem.. may also buy two new coil packs
    Veteran Member Three Rings bandit's Avatar
    Feb 18 2006
    Roundhouseville
    are you getting a CEL?
    Enjoy yo self
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    yeah, thats an ungodly spike. Whats year is you car?
    EDIT: nevermind, just saw you are a 00. ATW right? Are they as finicky as AWM with N75's?
    Village Idiot!!!
    (\__/)
    (")_(")
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Did you try bypassing the N75 valve so that the vac lines just go from the turbo housing to the wg actuator? This should cause the car to run very low boost, if it doesn't the vac line might be leaking or the actuator might not be pushing the WG open. If you do end up running very low boost you know it is most likely the N75 valve that is the problem.
