Results 1 to 12 of 12
Thread: turbo codes?
    Mar 14 2007
    MN
    turbo codes?
    When the turbos go on an S4 does it throw any codes off? If so what would they be?
    Veteran Member Three Rings alias747's Avatar
    Feb 19 2007
    La Crescent, MN
    Re: turbo codes?
    Your probably not going to need to have a vagcom tell you when your turbos go man, trust me. And when they do go you will probably get all sorts of fun codes, but nothing specifically to the turbos themselves.
    2010 S4 Meteor Gray | S-Tronic | Sport Diff | Nav
    Veteran Member Three Rings BlueturboS4's Avatar
    Feb 21 2006
    2010 s4, 2001 S4, 2002 dakota
    Re: turbo codes?
    you know there bad when you think your getting pulled over every time you boost!
    Mar 14 2007
    MN
    Re: turbo codes?
    oh i know what happens when they go i was just wondering if there is any specific codes that come up that anyone could tell me.
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    Re: turbo codes?
    you might get some of these
    17831 - Secondary Air Injection System; Bank 1: Insufficient Flow
    P1423 - 35-00 - -
    17819 - Secondary Air Injection System; Bank 2: Insufficient Flow
    P1411 - 35-00 - -
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-00 - -
    16690 - Cylinder 6: Misfire Detected
    P0306 - 35-00 - -
    17521 - Wallet too empty for car to function: Insert 6k into dashboard
    SBSC
    I also like to live dangerously.
    Registered Member Two Rings
    Mar 05 2008
    2001.5 Black S4
    SLO, California
    Re: turbo codes?
    LMFAO!!!
    Mar 14 2007
    MN
    Re: turbo codes?
    anyone else have an idea of what else could be thrown on the CEL!
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    Re: turbo codes?
    O2 sensor codes possible as well I believe.
    Brilliant Black 2001 S4 - 6MT <3
    Jun 14 2007
    2000 S4
    Connecticut
    Re: turbo codes?
    short answer. NO. there is no sensor on the turbo so when they go it doesnt do that.... you may get misfiring however, which can throw codes.
    Jun 14 2007
    2000 S4
    Connecticut
    Re: turbo codes?
    Quote Originally Posted by FrimmelNoJerz View Post
    in your case about 20k lol
    Sep 21 2006
    Norjerz
    Re: turbo codes?
    no. mine comes up as:
    09753 - fail: buy new car.
    SBSC
    Feb 17 2004
    Sterling, VA
    Re: turbo codes?
    Yup. Just spit coffee all over my PC....lol
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
