Results 1 to 14 of 14
    Oct 31 2005
    Ashburn
    Alarm always going off?
    Not sure if anybody else has experienced this but i was getting ready for work this morning and my alarm was sounding off, i tried to re-arm/silence it but it would work. So instead i used my key to turn it off and unlock the doors. then the car armed itself locked the doors and the alarm started to go off again.
    This happened repeatdly until i disconnected the battery terminal
    Could this be due to the battery in my keyless enty going dead?
    - Instagram: @Sinister_rs5-
    Active Member Two Rings bike867's Avatar
    Feb 06 2008
    2009 subaru WRX
    Brick, NJ
    Re: Alarm always going off?
    thats funny, I had the same problem about a year ago. I found out that the reason for my alarm going off was the construction site nearby, the trucks going by caused such a vibration that it kept going off and wouldn't give up......in your case I'm not too sure, construction site nearby?? lol
    Earthquake BP112 - AVIC D3 - LED License Plate
    Established Member Two Rings Doc_S4's Avatar
    Nov 03 2006
    Buffalo, NY
    It sounds like it could be the hood or trunk lid sensor. The sensor detects if the trunk or hood is opened while the alarm is set, when the sensor is bad the alarm will randomly go off when the cars locked.
    It happened to my car, i unplugged the sensor.
    Oct 31 2005
    Ashburn
    Quote Originally Posted by Doc_S4 View Post
    LOL, maybe i wasn't clear enough. The car will arm itself look doors and sound the alarm by itself, the buttons on my key won't turn it off unless i use the key to disarm it. Even then i get into the car and you can see the locks going up and down trying to lock themselves.
    if you actually seen it you would think the car was possesed.
    among other things like my windows not rolling down, an than a hour later they do. Hopefully i'll get the other ECU this week cause i think that is my problem
    Nov 03 2006
    Buffalo, NY
    possessed, that sounds good too!
    Senior Member Two Rings thebigchu's Avatar
    Oct 24 2007
    2004 Yukon Denali, 2010 Ibis S4 Prestige 6M
    San Ramon, Ca.
    Name her Christine...
    Do you have a Vag Com cable?
    2010 Ibis White S4 6M Prestige. Stage 1 (034 Motorsport). ADS, Sports Diff, B&O, Nappa, Tech package, 19" Trispoke.
    SOLD - 2002 Brilliant Black S4 6M ** Stage 1 ** (GIAC-X * JHM "Solid" Short Shifter * 034 DVs/TBB * Avic D3 * Clear Corners)
    http://www.audizine.com/classifieds/...inside-&cat=67
    Veteran Member Three Rings bandit's Avatar
    Feb 18 2006
    Roundhouseville
    sounds like the interior sensitivity needs to be turned down.
    Enjoy yo self
    Veteran Member Three Rings SourDieselS4's Avatar
    Feb 29 2008
    2001 S4
    New Hampshire
    Theres a button on the drivers side on the b-pillar for the interior motion sensor, push it to turn it off. I had a problem with mine going off constantly especially with the windows or sunroof cracked.
    Jan 09 2008
    01'NB'S4 sold 04 LSBlue M3
    VA
    Ok, very interesting that you started this thread because I was going to start one as well.
    My car has been ringing on and off without me realizing. I always wondered why I had codes for the car alarm. It seems to have to do with the interior motion sensor thing. That's what my vag-tool lists it as. However, when I tried pushing the button inside the car to turn off the motion detector, there were no lights, no sounds.... nothing. So I don't know if the detector is off or not anymore.
    Also, the alarm seems to only go off during times when my car has it's windows open.
    Oct 24 2007
    San Ramon, Ca.
    Quote Originally Posted by JayyyyyC View Post
    The interior sensor is an air pressure sensor. (Not a motion sensor) If you leave the window open a gust of wind can trigger the alarm. There is a button on the B pillar (the pillar in between the driver and passenger door) that disables the air pressure sensor. I press that when I leave my windows cracked and my alarm doesn't go off anymore.
    Apparently there is a Vag code to turn down that sensor. It's on my to-do list but haven't gotten around to it. Here's the AW thread about it.
    http://forums.audiworld.com/s4/msgs/321552.phtml
    Hope that helps.
    Oct 31 2005
    Ashburn
    Yeah, i know where the alarm senseitivity button is. I'm kinda a noob but i;m not that bad.lol It's my ECU, almost certain. When i try to VAG-COM the car it says ECU non communicatable, or something like that and it throws like 12 codes, my windows dont always roll up or down,
    Plus i dodn't think a senstivity button has anything to do with the alarm arming and disarming itself.
    Another example: Car arms itself/ none of the doors lock. how can the alarm arm itself without looking the doors?
    JayyyyyyyyC: pretty sure sensetivity button sounds like your issue, the button has a light on the left corner right next to the car symbol, it's very hard to see. Red it's on. no-light is off. let me know if see it.
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    I was searching around and found this thread on the air pressure alarm sensitivity button on the B-pillar... what illumination disables the air pressure alarm ? My alarm had been going off the past few days, so this morning I pushed that button once and a little light above the illuminated car came on, does that mean it has been disabled ?
    My car is fast
    Jul 21 2005
    Bedford/MA
    just found the answer on a different thread, when the light above the car is illuminated, the air pressure sensor is disabled. However I read that some people think it's a motion sensor on/off switch, and some people think it's an air pressure sensor on/off switch, what is it ?
    My car is fast
    Established Member Two Rings jesterekim's Avatar
    Aug 26 2007
    2001.5 Audi S4
    New York
    Quote Originally Posted by IamEzraM View Post
    The manual says motion sensor.
    Stage 2 | Brilliant Black | 6-speed
    GIAC X
    APR Stealth Catback
    APR Bi-Pipe
    Pro DFI Boost Gauge
