Results 1 to 4 of 4
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    easy fix?/what part is this?
    Alright, so as I was taking my driver's side turn signal out today (front stopped working a month or so back) I noticed this. I assume this is why it isn;t working. There should be 3 prongs, there is only 1 in the center, other 2 broke off? interesting.. haha Is there an easy way to possibly fix this, if not what is this part called and any idea where I can buy one? besides dealer. TIA
    Veteran Member Three Rings xAUDIx's Avatar
    Jan 08 2007
    1998 Audi A4 2.8 30v
    Bolingbrook, IL
    Re: easy fix?/what part is this?
    Need better pics, lil too blurry to see whats going on..
    And you did try replacing the bulb right? Could just be burnt out..
    -NICK
    FIGHT ME http://no-bs.mybrute.com
    Feb 28 2007
    04 a4 USP ; ATS
    if you read what I wrote, I explained what is going on. The bulb, I know is fine I tested it on the other side.. I showed you the first pic so you could see what it is. The second two show the INSIDE of that plastic housing type thing the bulb goes into. There is 3 little metal/silver prongs that stick up. The 2 side ones are both snapped off at the bottom, the middle one is still there.
    Established Member Two Rings Urbndevelopmnt's Avatar
    Jul 04 2007
    2005 A4 Cabriolet, 1996 A4 2.8
    East Rutherford
    Dealer or junkyard...or someone who's parting out their car.
