Results 1 to 3 of 3
    Senior Member Two Rings Asix's Avatar
    Jan 25 2008
    Audi S5
    Bellevue, WA
    Anybody Know If There Is A Drl Kit?
    Hey guys. I know some of the A6's out there have DRL's and I was just wondering if anybody knew if there was a DRL aftermarket kit out there?
    Veteran Member Four Rings white fish's Avatar
    Feb 21 2004
    05 allroad(old) 10 Q5 10 S4 13 S6
    T.O.
    Re: Anybody Know If There Is A Drl Kit?
    I herd something about taking out the switch for the lights and wiring the fogs to come on all the time
    (without having to do the "ulgy" jumper mod on AW)
    Senior Member Three Rings skiroad'r's Avatar
    Apr 21 2008
    2002 allroad Tip, 2005 Mazda 6 Wagon 5MT
    Central New Jersey
    there is not an "off the shelf kit" that I know of
    However there are a few write-ups on different methods depending on what you are trying to ultimately accomplish.
    Some of the folks that have imported A6's and allroads into Canada have had to retrofit a DRL solution. Here is an excerpt from another thread:
    Using a wire tap connector, connect the headlight switch #8 (white/yellow) wire to the #2 (grey/green) wire. This will permanently turn on the front fogs (as long, of course, as you have made the appropriate fusebox tap connection so that the fogs are powered as soon as the ignition is switched on and not just when the low beams are on). The wire tap connector is a $2 item from Radio Shack and has two blades in a plastic enclosure that make contact between two wires without having to alter the wires in any way. It's easy to remove once the Transport Canada inspection is completed if you prefer.
    Incidentally, this does not affect the high beam foglight defeat or the rear foglight functions.
    Here is link to full thread:
    http://forums.audiworld.com/allroad/msgs/214561.phtml
    '02 allroad 2.7T Tip
    ASP Flash, 034 Snub Mount (DIY), VAST EFK (DIY), H-SPORTS (Hard)
    Anrott Gen II Front Airsprings (DIY), Magnaflow mufflers with 3.5" tips
    Summers: Yokohama Avid W4S/RS6 Reps
    Fog DRL's, Toggable 628 Relay, Tip Override Recode, Remote Window Recode, Clear Corners (DIY)
    Timing Belt DIY (at 60K miles), Tiptronic Drain & Refill Service DIY (at 62K miles)
    GET OEM PARTS HERE: http://www.europaparts.com/
