Results 1 to 11 of 11
    Veteran Member Four Rings casawhites4's Avatar
    Jan 21 2007
    01.5 Silver Avant
    dc
    took a road trip and engine temp dropped all the way to C...
    and then back to the middle again, then it dropped all the way to C again...kept on driving a little and jumped back up to the middle, know after driving back from rutgers..the needle is never in the middle its always a little towards the C or a whole line over...any ideas??
    01.5 Stage 3 Casablanca White S4 (GONE)
    01.5 Stage 0 Silver S4 Avant (New Project, def Grocery Getter)
    watch out Casablanca!!! im coming back with a vengeance!
    Silver will be the fastest now!!! :-D
    Jun 14 2007
    2000 S4
    Connecticut
    Re: took a road trip and engine temp dropped all the way to C...
    lol i answered on AW, isnt that the Tstat stuck open?
    Veteran Member Three Rings ubermidget's Avatar
    Dec 08 2006
    Boston, MA
    yeah my car used to do the same thing....thermostat
    EPL Stage 3 Aquamisted
    Jan 21 2007
    01.5 Silver Avant
    dc
    lol, yeah ya did audisport...so is it something i should worry about it right now...or is it an easy fix...im assuming it is then
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Having the temperature gauge jump up and down can be caused by thermostat being stuck open or closed, normally when this happens the car will overheat.
    Having your gauge jump between totally cold and half way is the temp sensor.
    even if the thermostat was stuck all the way open there is no way the temp gauge would go completely back to cold. So this is why I would bet my money that it is the temp sensor. Usually it will throw a CEL (but not always) and should be triggered in Vag-com as a temp sensor not reading right.
    These are known to go bad. They are cheap - 20 bucks and easy to replace. There is a writeup on audiworld, and may be one here on audizine too, just havnt looked. My gauge worked fine but was constantly getting a CEL, I finally vag'd it when I got a cable and found this to be the problem, replaced it on the street now is golden.
    FYI if your car overheat's pull over and shut off immediately and do not drive!!! You can ruin your engine if you try and continue to drive it.
    You probably know that, but just thought safe then sorry
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Jan 21 2007
    01.5 Silver Avant
    dc
    but i already swapped to the green temp sensor...and its only happened twice on the way up to rutgers which would be friday...not once since then...
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    I C. Hmmmm well it could be the thermostat, but like I said it woudlnt go all the way to cold if the gauge was working correctly after the engine is warmed up.
    How long ago did you switch the green temp sensor? maybe the new one was defective.
    If it is the thermostat though, you have to tear the front of the engine appart to get to the thermostat. Not an easy job. So I would center on the temp sensor and make sure thats not the problem. Is it leaking any antifreeze?
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Quote Originally Posted by gointoscott View Post
    this is not true... any car ive had with the TStat stuck open has dropped all the way down to cold unless its 80+deg outside.
    the temp gauges in cars usually dont start reading till 100+ so anything below that will be on C..
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Quote Originally Posted by JDM EJ1 95 View Post
    This may be so, but I still find it hard to believe the temp of the engine would drop that low to have the temp gauge drop to Cold, unless it was really cold out. But I guess it could be possible.
    Deactivated Four Rings
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    When my coolant temp sensor went out on my A4 it did not show a CEL - but it threw a code.
    Check that before you dig out your thermostat.
    Jan 21 2007
    01.5 Silver Avant
    dc
    well i feel like if the sensor went out, wouldnt the gauge be stuck in the off position...like not readin at all...and how about...now..the gauge is just over to the cold section by one line...(hopefully you guys understand)
