Results 1 to 11 of 11
    Established Member Two Rings stylesx's Avatar
    Aug 09 2007
    Sick Bicycle
    Oakville
    Wheel Spacer Question
    Does anyone know off the bat if spacers from a BMW 330ci would fit an Audi A4 since i have a new set from my previous car.
    Thanks !
    Jun 14 2005
    Anaheim, CA
    Re: Wheel Spacer Question
    If they are cheap universal 5x120 and 5x112 ones they can... Most spacers iv seen for European cars are hub centric and lug centric.
    -Charles@VMRWheels
    Brandon @ VMR Wheels
    Established Member Two Rings thomas33's Avatar
    Dec 04 2007
    Salt Lake City
    where can you get some spacers? how much are the for a b7 a4?
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    H&R makes a great line of spacers we don't sell. You may want to give them a call @ 888-827-8881
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by thomas33 View Post
    We source our spacers from H&R as well.
    -Charles@VMRWheels
    Oct 06 2006
    South Bend, IN
    I stand corrected. Good to know
    Jun 05 2007
    Syracuse, NY
    Sorry for the thread jack...but where can I find longer lugs if I use spacers with stock wheels?
    Jun 14 2005
    Anaheim, CA
    I believe tire rack sells longer lug bolts. Give Doc a ring and im sure he cant help you out. Tirerack doesnt put small items like that on there website.
    -Charles@VMRWheels
    Veteran Member Three Rings Alpinevelo's Avatar
    Dec 28 2006
    06 VW Jetta I5 daily driver bone stock 4 now
    Fountain Hills, AZ
    Question Re: Wheel Spacer Question
    Quote Originally Posted by VMRWheels View Post
    -Charles@VMRWheels
    Yes they actually sell Kits just be careful measuring. Measure twice buy once. I've seen them for about $130.00+ for two wheels (1 Kit) You can even get them in anodized black so they won't be noticeable if that's a concern.
    Question for Doc and Charles: Can spacers cause problems with my wheels? I inquired with a local tire company about mounting my new wheels and putting spacers on and they said that they will not do it because "it's not recommended"
    C5 A6 2.7T GIAC software Stage 1, EVOMS DV Valves, Cupra spoiler lip, RS4 OEM 18" Wheels.
    Alex
    Oct 06 2006
    South Bend, IN
    We avoid spacers all together (unless provided by the wheel manufacturer for a specific fitment) for liability reasons. Anytime you put something in between the wheel and the hub there is potential for problems (spacer not hub centric, wrong lug bolts used, etc) Anyone selling the spacer should be able to guarantee a hub centric fit for your specific model and provide the correct length bolts as part of the deal. I'd rather use a wheel that has the correct ET than try and fudge something that isn't right.
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by Doc@tirerack View Post
    Nicely said.
    -Charles@VMRWheels
