    Established Member Two Rings Urbndevelopmnt's Avatar
    Jul 04 2007
    2005 A4 Cabriolet, 1996 A4 2.8
    East Rutherford
    A question of wheels...
    I was purchasing new wheels for my b6 cabriolet and i started to thing, could i put my cabriolet's stock 17" wheels on my b5? Would they clear correctly?
    thanks!
    Veteran Member Four Rings tamadrumr88's Avatar
    Nov 03 2006
    lehigh valley pa
    Re: A question of wheels...
    i had the b6 5spoke 17x7.5 et43 on my b5. with 235/45-17 tires i needed a 5mm spacers and extended lugs for the rear wheels because they rubbed the control arm up top. others have run the same with but with 225/45-17 and had no rubbing issues
    Jul 04 2007
    East Rutherford
    hmm...i test fitted one on the rear since i have a FWD and nothing rubbed, then again the tires on there now are i BELIEVE are 235-55-17's,but they may be 235-45-17...
    i guess i should just put them on and try it out,but from what i saw,there was no rubbing in the rear,well for 50 miles at least
    Jul 04 2007
    East Rutherford
    Yes,its 235/45/17...
    But you said your fronts cleared right?
    Nov 03 2006
    lehigh valley pa
    yes fronts cleared but not the rears. the suspensions are different between fronttrak and quattro so that could explain why your rears fit and mine did not
