Results 1 to 12 of 12
    Mar 23 2008
    philippines
    Help!!! car won't run!
    guys i need some help! i just got a 95 1.8T and it was working fine for the past 2 days then just awhile ago when i was moving my parking spot i heard a thud then it just wouldn't run anymore! so i turned it off then started it again, now its weird, i can put the car in gear without stepping on the clutch. when i let go of the clutch while its in gear, the car doesn't die! please let me know what the problem could be it would be very much appreciated!
    Mar 23 2008
    philippines
    Re: Help!!! car won't run!
    anyone?
    Dec 05 2007
    CA LA
    so you put it in gear but it wont move. hhmmm clutch craped out?
    Mar 23 2008
    philippines
    yup it wont run when its in gear. and when i put it in first (or any gear for that matter) then let go of the clutch the engine doesn't die.. any ideas?
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    Driveshaft? Was it making any noises before??
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Mar 23 2008
    philippines
    well ive only been driving it a couple of days but no weird noises that i know of. brought to a shop nearby that also work on audis and the mechanic said it could be something with the axle. hes not sure thought coz he hasn't fully diagnosed the problem. anybody have this happen before?
    Active Member Two Rings AudiRepair4Less's Avatar
    Apr 11 2008
    Long Beach
    Sounds like you broke an Axle..... Check you speed if you put it in gear. If you put in in like 2nd, and the Speed moves on you cluster. but car aint going anywhere mosty likely an axle. Easy way to check is turn wheels to one side, and Grab the axle and Shake it up and down, or have someone put it in gear and take a look to see it any axle is Spinning. If you find one spinning thats the broken one. Since the car isnt moving but axle is....
    Mar 23 2008
    philippines
    Quote Originally Posted by AudiRepair4Less View Post
    i think that this is the problem exactly. i saw the passenger side axle spinning when i looked through the engine bay. is it a major thing to fix? will i need a new axle or is this repairable?
    Active Member Two Rings Monk's Avatar
    Dec 13 2007
    98' A4 1.8TqM (AEB)
    Philippines
    ^ Best is to place the car on a hydraulic lift or jack-stands so that you can check for shaft-play due to worn-out splines. Driveaxle problems can also be attributed to damaged CV joints (usually by neglecting cracks on the CV boots).
    Replacement is pretty straightforward, it's just a matter of sourcing out the parts.
    B5 1.8TqM (AEB) :: GTRS :: Mika E-PROM :: RC 550cc :: Walbro 255LPH :: 3'' Inlet & MAF housing :: TS MBC :: BaileyMS DV :: EvoMS FMIC :: Phenolic spacer :: ATP x-mani :: Supersprint Testpipe & Exhaust :: Innovate XD-16 w/ LC-1 :: Southbend OFE stg.3 :: Boxster 4pots :: etc.
    Mar 23 2008
    philippines
    Quote Originally Posted by Monk View Post
    talked to the mechanic and he said it was my outer velocity that got busted. he was able to source out a part for 13k (pesos). hopefully thats all it is and i can get it up and running in a few days.
    Apr 11 2008
    Long Beach
    Thats good you find the problem, Glad i can Help, PM me if you have any problems i can fix via emailing. :)
    Mar 23 2008
    philippines
    hahaha! will do bro thanks!
