Results 1 to 9 of 9
    Mar 23 2006
    Vancouver, Canada
    Spring compressor in Vancouver
    Does anyone in Vancouver have a spring compressor? Or know where I can rent one?
    I need to raise the front coilovers by about 1/2" and I've reached the max .height that I can do with just the collar wrenches. The spring tension is just too much to turn the collar perch further. Thanks in advance for any help.
    Veteran Member Four Rings white fish's Avatar
    Feb 21 2004
    05 allroad(old) 10 Q5 10 S4 13 S6
    T.O.
    Re: Spring compressor in Vancouver
    dont know if you have canadian tire there
    they have loan-a-tool
    Senior Member Three Rings archimense's Avatar
    Jan 16 2006
    Vancouver, Canada
    I bought mine from KMS Tools for $10 or $20 dollars.
    2001.5 Audi S4 stg 3
    K04s, 85mm MAF, 60lb injectors, custom software
    ASP DTS/Tru-Dual/Downpipes
    Stasis Tracksports/4:1 Centre Diff
    Neuspeed 19mm rear sway - CPP rear end links/tie rod ends/front upper control arms
    VAST ceramic clutch, RS4 pressure plate, JHM shifter
    RS4 engine/trans mounts, Stern rear diff/snub mounts 55 watt HIDs, Odyssey PC680 battery, Innovate Wideband
    Mar 23 2006
    Vancouver, Canada
    Quote Originally Posted by archimense View Post
    Wow, that's really inexpensive. What type did you get? Was it safe to use?
    Jan 16 2006
    Vancouver, Canada
    I've used it to do springs on three of my cars now. Never had a problem.
    Mar 23 2006
    Vancouver, Canada
    So which type did you get, or do they only carry one type?
    Sep 20 2006
    Burnaby, BC, Canada
    just go to crappy tire in coquitlam, they do tool rentals. you just leave them a deposit and when you bring the tool back they refund it. the lending is free.
    Sep 20 2006
    Burnaby, BC, Canada
    but you shouldnt compress your springs so much that the tension is too much to turn the wrench... but its up to you
    Mar 23 2006
    Vancouver, Canada
    Thanks, the CT at Cambie does the loan-a-tool thing as well so I'll go on Friday night to borrow it. Thanks for the insight about adjusting the perch height vs. spring compression. I want to get the height at 25.25", so I'll need to raise about 1/2". Hopefully that won't compromise the spring's performance.
