Results 1 to 3 of 3
    Apr 14 2008
    2008 A4 SE Quartz Gray 2.0T
    Revo Question - the "off" switch for servicing?
    Hi,
    I was curious, I have seen mentions of the Revo unit & that you can put it in "stock" mode (something with the cruise control). How does that work? Is it done via software or hardware (the defeat switch).
    Thanks,
    Rich
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    Re: Revo Question - the "off" switch for servicing?
    you use the select or select plus switch. get the select plus switch. you spend more but you can control boost, timing and a/f ratio. it plugs into the obd port, you make the change, and unplug it.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Senior Member Three Rings BLACKa4QUAT's Avatar
    Mar 26 2008
    union city, ca/fort worth, tx
    will the sps2 work?
    2006 A4 2.0Tqm, S-line, tech, FH-P8000BT, 10" sub, 800 watt,
    VAG-COM mods (remote windows, no chime), revo stg 1 tweaked
    AWE pedals, HRS4 DTMs/Eagle GT, VMR TP
    193.7 awhp/232 ft/lb/91 oct pre-TP
    16MAR09DSWHTAW
