Results 1 to 9 of 9
    Feb 17 2005
    Sarasota, FL
    OEM Bi-Xenon Replacement/Help
    Friend of mine has OEM Bi-Xenon's on his 02' A4, one of the ballasts is burnt out. He swapped bulbs and igniters and both work on each side, the one ballast however does not. From the dealer, even my cost, is ridiculous. Is there an aftermarket HID kit or some other type of replacement for the OEM xenon's?
    Thanks, Shawn
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Re: OEM Bi-Xenon Replacement/Help
    Maybe you could work something out with this: Clicky click
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    HIDConcepts.com They have the factory OEM Valeo ballast kits for like $110 per ballast.
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    I have all of my lights high, low, and fogs done with their kits and they're top notch.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings pyro's Avatar
    Mar 18 2007
    '05 A4
    Tampa, FL
    you can find OEM ballasts super cheap on ebay all the time. thats where i got both of mine from.
    i dont recall there ever bring a bi-xenon option in 02 however.
    you have to be careful with what aftermarket ballast you might buy, because 02 used a completely different setup and if it doesnt fit right moisture will get into the housing, etc.
    Veteran Member Four Rings A4TUNE's Avatar
    Sep 14 2006
    Mass
    ^ I'm sure he put the bixenons in they don't actually come on 02's.
    -Max
    2004 A4 1.8T M6 Quattro Ultrasport
    REVO Stage 1 | AWE Boost Gauge | Carbonio CAI | Valeo Single Xenon Black Ecodes | RS4 Rear Sway Bar | 18x8 OZ Superleggera | DTH USP Splitter
    Mar 18 2007
    '05 A4
    Tampa, FL
    thats what i just throught...either way i just looked and there are a few ballasts on ebay right now.
    Veteran Member Three Rings joe.audi's Avatar
    Nov 28 2006
    b6 a4 ,1985 jetta
    N.H
    Quote Originally Posted by RLB6 View Post
    HIDConepts.com They have the factory OEM Valeo ballast kits for like $110 per ballast.
    02 sedan built 1.8 big turbo on meth
    REVO software
    HBC tuning
    Nov 02 2007
    03 B6 1.8T TIP
    Richmond
    go to AKINBOY (AZ user)
    he and HIDconcept is pro at this
    "When you love somone, you let her sleep well"
    My...2005
    Coiming this Summer: VIS Carbon Trunk w/carbon lip spoiler. CF splitter...
    "The fastest B6 TIP in Richmond BC"
