Results 1 to 7 of 7
Thread: revo select
    Apr 05 2008
    Vancouver
    revo select
    what do you guys think of the revo select ecu flash
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Re: revo select
    Its like afterburners
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Jul 04 2007
    Anchorage, AK / Chicago, IL
    Re: revo select
    How hard/safe is it to adjust the settings correctly?
    Oct 14 2006
    MK6 Jetta
    South,FL
    Re: revo select
    Really easy, and if you adhere to revo guidelines for the setings is really safe.
    -EI AL CAI.
    -Driver Mod.
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    Re: revo select
    youre thinking of the select plus switch. its easy to configure, but you need to datalog with vag-com to fine tune for optimal performance, the select switch just toggles between performance and stock, leaving you with no room to go up.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Senior Member Three Rings BLACKa4QUAT's Avatar
    Mar 26 2008
    union city, ca/fort worth, tx
    Re: revo select
    i have a question and dont want to make another thread, but i can get sps2 from a b6 a4 for extra-cheap, and was wondering if it would work with my b7 w/revo.
    2006 A4 2.0Tqm, S-line, tech, FH-P8000BT, 10" sub, 800 watt,
    VAG-COM mods (remote windows, no chime), revo stg 1 tweaked
    AWE pedals, HRS4 DTMs/Eagle GT, VMR TP
    193.7 awhp/232 ft/lb/91 oct pre-TP
    16MAR09DSWHTAW
    Mar 11 2008
    07' A4 S-Line ti avant
    Toronto Canada
    Re: revo select
    Quote Originally Posted by HID View Post
    Really..... Does it burn more gas..
