Results 1 to 6 of 6
    Senior Member Two Rings JMVant's Avatar
    May 27 2007
    Tire brand mixing
    I have two goodyear f1's that I want to toss on my summer rims but need two more tires. Was thinking I would be cheap and mix brands and was wondering what I need to worry about. As long as they are the same size should I be okay??
    __
    B7 A4 S-Line
    Current project
    Jun 14 2005
    Anaheim, CA
    Re: Tire brand mixing
    Use the same type of tire. Meaning (all summer or all season). Dont mix both of them together. Put the newer tires in the rear just in case of rain or any kind of high speed maneuver.
    -Charles@VMRWheels
    Brandon @ VMR Wheels
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    We discourage mixing tread patterns as well, because different tread patterns shed water and resist hydroplaning differently. Combine a different tread pattern with differences in tread depth, and things can get slightly unpredictable in wet weather.
    Senior Member Two Rings MikeS4's Avatar
    Feb 14 2008
    searching for something new
    Savannah
    after my alignment issue discovered during my 35k service, i put two falkens or something on the fronts and stuck with pirelli p zero neros on the back because they were damn near brand new.
    important note, i didnt really care because my car went to my parents a week after, and is there now while im stuck in afgahnistan for a year. i dont think my dad will be doing any track days with it....at least i hope not.
    they did drive it about 2k miles cross country to get it home and they didnt report any issues.
    if i was going to drive it extensively after the switch i may have put p zeros back on... but then again maybe not.
    just put the same size and rating on as the other ones.
    edit: 2004 S4 stock 18's
    Veteran Member Four Rings EYE4SPEED's Avatar
    Jan 14 2008
    Macan Turbo, Cayenne Diesel, Audi Jr Quattro
    West Coast of Michigan
    I heard that Quattro needs to have the same tread pattern...
    FS: Audi TT 225Q Roadster
    May 27 2007
    Quote Originally Posted by EYE4SPEED View Post
    So far I hear as long as speed rating and rotational diameter are same it won't harm qt system. Tread pattern may effect wet weather traction as it does on all cars.
    __
    B7 A4 S-Line
    Current project
