Originally Posted by
Tgr_Clw
There's only 1 fuel filter in our cars. It also has the fpr built in.
Wrong there are two fuel filters for the audi b6 a4 one ending in g and the other J. One is for a Fwd and the other is for the Quattro. they recently updated the fuel filter, and now end in the Letter L. Also there are Two different Fuel pumps. Fwd is located in the trunk under the Back cover. And for the quattro, it is located under to the rear pass side seat..... The reason for the Failure is really not understood right now, but in order to fix the problem, both pump and filter need to be change. Some say it's the fuel pressure reg. in the filter that get clogged killing the fuel pump. From replacing these things many times, I now that just replacing one at a time, wont normally fix it....... I advise to replace fuel filter first, and before starting the car to check the repair.... replace pump, so that way u have both new before you start. Hope thats a help......
