Results 1 to 6 of 6
    Senior Member Two Rings algee007's Avatar
    Apr 10 2008
    B6 S4
    DENVER
    Left light dipped???? What the Heck???
    So I literally have had this car for 12hrs...and it rained last night and this morning right....some condensation is under the light covers and I get it it to go to the store....I get this alert that the left light is dipped...so when I get to a stop I get out and look...and the bulb isn't on????
    Can anyone tell me if the condensation has something to do with this and once the moisture is out of the light assembly...will the light fire up?...or am I screwed?
    Registered Member Four Rings
    Jun 14 2007
    2007 A4 2.0T QM 2008 A8L
    New York
    Re: Left light dipped???? What the Heck???
    I hate it when people don't post any information about what year car they have, etc.
    Still under warrenty?
    Veteran Member Four Rings bwoy1981's Avatar
    Oct 28 2006
    2005 Porsche 911 997 Manual, 2022 Hyundai Tuscon
    Orlando, Florida USA
    Its the moisture. You should be fine once the moisture dries up, but you need to get he headlight housing looked at or do it yourself, cause you cant have water getting in there all the time.
    This has happened to me about 8 times till finally my ballast got wet then it fried so I had to source a new one. GL!
    Current: 2022 E-Tron Sportback Premium Plus, Siam Beige, S-Line, Black Optic Package, 22x10.5 Q8 Rotors, 285/35/22 Continental DWS 06 PLUS
    TOY: 2005 Porsche 911 997 Carrara White / Black Interior 6 Speed manual, Aero Kit,
    BC Racing Coilovers, FABSpeed Exhaust, Headers & Intake, 991 GT3RS Reps "GOLD"
    Registered Member Two Rings The Broker's Avatar
    Feb 27 2008
    E90 M3 - MK5 Rabbit
    I had the same issue with mine on both sides.....I had the control modules changed under warranty and never had the problem again.
    Apr 10 2008
    B6 S4
    DENVER
    Thanks for replying, much appreciated....It's an 04 S4, and it's not under warranty, after some of the condensation went away I tried them and they do work...thank god, but when you pull the assembly out...I should dry it out with a hairdryer right??? and then look for the leak and silicone it???...has anyone done this type of repair, and or know of a post that shows this??? I have a Bentley manual for my A6, so I'll scan that for the replacement bulb procedure and take it from there...if anyone knows of a good DIY for this, if you wouldn't mind pointing me in the right direction it would be greatly appreciated...
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    i have this problem on my left side. the dealer replaced my headlight range control module SOFTWARE but not the module itself. and the problem is still here.......
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
