Results 1 to 16 of 16
    Senior Member Two Rings audienthusiest's Avatar
    Apr 06 2008
    nada
    CALI
    Oil sensor warning light??
    OK guys i think i've got a new one for you. So i had an oil sensor light go off on the dash today... anyone know whats going on with that? Is it just one of those take it to the dealership and leave it and never know wat went wrong wit it sorta thing or is it just like pick up a new sensor and do it myself.
    Or more likely was it a ripple in the computer and should i just ignor it until it comes up again?
    I have a 2001.5 audi a4 1.8 turbo btw
    Thx very much as this has me perplexed...
    Registered Member Two Rings NeubsA4's Avatar
    Jan 30 2008
    01.5 Audi A4 1.8t
    Buffalo, NY
    Re: Oil sensor warning light??
    Sounds like you are just low on oil. Or your oil might be spent and needs to be changed. Check your oil level.
    Apr 06 2008
    nada
    CALI
    i already did... a it was clean and full... i had it changed less then 1000 miles ago... the manual said it was a bad sensor light....
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Is it the oil symbol that comes up in the display screen? If so it is a bad oil pressure sensor which is located near the oil filter. What you can do is unplug it and see if you get any other lights coming up because I know if that sensor is not plugged in a oil warning symbol comes up on the display screen.
    Veteran Member Three Rings ////D's Avatar
    Aug 22 2007
    847 IL
    do you get 3 beeps with that? i have the same thing i think, except my mfd is broken so i can see what its saying.
    Apr 06 2008
    nada
    CALI
    well its not the oil pressure warning light and its not the normal oil warning light. When it comes up it shows the oil can and then just says sensor below it. The manual said to replace the senseor? Would going in and unplugging it and plugging it back in reset it because i have never heard of this problem b4.... thx
    Apr 06 2008
    nada
    CALI
    ya i get three beeps... but it doesnt always show up.
    Jul 07 2004
    socal
    Quote Originally Posted by audienthusiest View Post
    You might just have a bad connection at that sensor.
    BTW is this the symbol you get?
    Apr 06 2008
    nada
    CALI
    ya thats it... sooo just a bad connection? should i worry about it now or put it on the list of things todo
    Senior Member Two Rings mravantit's Avatar
    Mar 20 2007
    is full
    Alberta
    might be oil sludge........ how many miles?
    2016 Audi RS7 - Misano Red Pearl, APR Stage II, S8 rotors, KW H.A.S.
    2008 Audi R8 4.2 - Ibis White, O.Z. Ultraleggera wheels, TCU Tune, Milltek Exhaust, H&R Springs
    2012 Audi TT-RS - Misano Red, KW V3's
    2002 TVR Tuscan Speed 6
    insta @polskigosc
    Apr 06 2008
    nada
    CALI
    87000.... thelight only comes on occationally... ive owned the car since about 84000 miles... and i baby it.. synthetic oil every 1500 miles and i changes the filter too... i use premium gas... idk where i would be getting sludge unless the cars past was worse then i thought.
    It only comes on occationally... is it posible its just a glitch in the computer?
    Mar 20 2007
    is full
    Alberta
    yes it is but i had the exact same problem before. There was a TSB at Audi for it. To me it sounds like you might have sludge. Pick yourself up a couple cans of Lubro Molly Engine Flush, do it once, driver around for 1k miles, do it again, fixed my problem!
    insta @polskigosc
    Apr 06 2008
    nada
    CALI
    cool thx so much for the insight!!!
    Apr 14 2008
    a4 avant
    marlboro
    id say the motors sludged, same thing happend on my audi with 110 on the clock and i only ran synthetic...its all about how the person before you treated the car
    however hopefully that engine flush fixes your problems
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    the sensor is only what? $5-10? I say just replace the sensor or remove your valve cover to get an idea if it's possibly oil sludge. I suppose an engine flush couldn't hurt if it's not expensive.
    oh yeah, and changing your oil every 1.5k miles is ridiculous. even 3k is overkill.. even though thats when i usually change my oil. I good synthetic won't start breaking down until 5k+
    Veteran Member Four Rings LateraLex's Avatar
    Jun 13 2005
    A4 1.8tQM 01
    the mean streets of Boston
    Mike do you have a picture of where this sensor is? I have a different but similiar issue... I swapped the EEPROM from an A4 cluster to an S4 and it was working fine, now I get low oil warnings. I replaced the oil level sensor, and my oil is never actually low. I think the cluster is bugging out. If I pop my hood the light goes away, but comes back after say a few hours of driving. I might want to check out this sensor you speak of as well...
