Results 1 to 15 of 15
    Veteran Member Three Rings RuS4ty's Avatar
    Mar 13 2006
    VA / MT
    Fixed one problem, now another evolves...
    So I finally fixed my misfiring problem the other day by replacing the spark plugs (replaced with NGK platinums) ... and now my boost is acting weird.
    So as you can see it spikes (18psi), then drops (9.7 psi), then spikes again (17psi) then goes to the shitter (8psi). The odd thing is that it never request anything over (13psi). I had an issue similar to this a couple weeks ago which was due to a boost leak (torn TBB) which graphed like this:
    Not quite the same though.
    So could this possibly be due to the wastgates (n75)? I logged those but I'm not sure how to read it. I started to pressure test but didn't have anything to seal off the PCV hole, but noticed slight amount of oil in the accordion hose and a good amount in the TBB.
    Any idea??
    btw I'm GIAC stage 2+...
    *NEW Addition: Misano Red RS4
    01.5 S4
    For sale(pm me for details):
    FRONT AIRBAGS !CHEAP!
    Stock S4 swaybar
    "I'd have one of those... if I were the sort of person that looked at my sister and thought, mmm..." - Jeremy Clarkson about the Roush Mustang.
    Registered Member Three Rings volks88's Avatar
    May 06 2007
    stg3 s4,02 C32 AMG,88 325IS
    lexington,ky/fond du lac,wi
    Re: Fixed one problem, now another evolves...
    get a MBC and bypass the n75
    Dec 06 2007
    Calgary, AB, Canada
    Log the N75 duty cycle.
    Mar 13 2006
    VA / MT
    Ask and you shall receive...
    Quote Originally Posted by volks88 View Post
    As far as a MBC goes, I've really only heard about the vast one being used, are any of the other options any good (i.e. forge from ecs, or the turbosmart one)?
    01.5 S4
    Stock S4 swaybar
    May 06 2007
    Quote Originally Posted by RuS4ty View Post
    i used a buddy's turbosmart. i was just eliminating my n75 being bad when i was trouble shooting.
    Junior Member Two Rings
    Apr 11 2008
    2007 Audi RS4
    Charleston, SC
    I bought a cheapy nxs mbc from ebay and installed it inline with my n75. I need to do some fine tuning, but it will cut out the boost spikes.
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 15 A8L, 16 PSD F350
    Longview, WA
    Correct me if i'm wrong, but I thought pltn plugs were no good in our cars?
    --Mike--
    01 Casa S4
    03 Mugello RS6
    15 Moonlight A8L TDI
    01 Aviator TT (sold)
    99.5 Santorin A4 (sold)
    04 Cobalt Allroad (sold)
    Mar 13 2006
    VA / MT
    I'm pretty sure the laser platinums (PFR6Q) are what comes stock with our cars
    01.5 S4
    Stock S4 swaybar
    Veteran Member Four Rings lrg8683's Avatar
    Nov 02 2005
    S4
    VA
    MBC/TCD.. why you STILL haven't done this is beyond me.
    -Luis
    Jan 12 2008
    WV
    oil in the accordian and tbb is NOT normal. I had some residual oil in one of my black plastic intake pipes from a failed turbo (that has since be replaced). That oil could have messed with you MAF sensor. Unplug it and see if you still get the boost spikes. If not clean your MAF with some throttle body cleaner. Good luck.
    Mar 22 2005
    2019 RS5 SB / 2017 Jeep SRT
    FL
    Pressure test before you start adding stuff to your car. Looks like a boost leak to me. If you're stage 3- and below stick with Bosch Platin (not platinum) F5dpor plugs. Expensive, but they work the best. As stage 3, I use NGK BKR7E's. They are $2 copper plugs but they work great. But because they are copper you have to replace them every 5-10k miles, vs. the platins that you can run for 20k+.
    As for the oil... it all depends. Alot of oil in the TBB probably isn't good. I have seen some ioil n the accordian hose / Y pipe before, because the PVC is right there. So that bit is probably "normal".
    Dec 06 2007
    Calgary, AB, Canada
    Bosch platins are fine for most stage 3 setups as well.
    I need the N75 duty cycle log, not the boost log.
    Looks to me like the problem is a bad N75 valve.
    Mar 13 2006
    VA / MT
    The duty cycle is in pink.
    It was snowing and 1 degree out, so I wasn't able to do anything today. I did notice a small crack where the y-pipe splits to the PCV which would letting air out... but that shouldn't effect anything major.
    01.5 S4
    Stock S4 swaybar
    Dec 06 2007
    Calgary, AB, Canada
    My bad, I didn't notice that the N75DC was on the same graph.
    That's very odd. Have you pressure tested the N75 reference and the WG lines? Have you tried swapping in a different N75?
    Mar 13 2006
    VA / MT
    It's cool, I just did that for reference of when it was boosting.
    not yet, thats the plan when the weather clears up.
    01.5 S4
    Stock S4 swaybar
