Page 1 of 13 12311 ... LastLast
Results 1 to 40 of 513
    97 A4 2.0TQM
    Rochester, NY
    2.0 AEB / Holset H1C Build Thread
    i was at the drag strip today and blew the motor on the last run.
    symptoms:
    smoke everywhere
    almost complete loss of power (i was still able to limp it off the track)
    blew out the seal on the oil filler cap
    blew out the dipstick
    blew the line off my catch can
    oil in cylinder 4 (1, 2 and 3 are fine)
    oil all over the inside of the motor under the intake manifold, it blew all over the inside of the hood too (probably from the filler cap / dipstick / catch can line)
    its pouring oil out everywhere (i had to put about 10 qt's in on the trip home) but I'm not sure from where, i don't see any holes in the block and im pretty sure I didn't break a rod.
    I knew it was commin, so here it was. 2 years with BT on stock motor is OK in my book!
    best e/t was on the last run (13.37 @ 102) where i blew it, nearly perfect launch, caught the gears just right, but revved too high at the top of 3rd (7600rpm)
    my best mph was 107, shifting into 4th with the 2.8 transmission sucks for drag racing.
    not fast runs, but the car hasn't been tuned by anyone but my self so im pretty happy.
    it launches like a bat out of hell, it was sick! the launches were pretty consistent, my best 60ft was 2.093
    parts list as of 5/1/08:
    OBD-I ABA Crankshaft
    Scat 144mm Rods
    Wiseco 83mm custom pistons (ordered, eta 2 weeks)
    Glyco main bearings (to be swain ppm coated)
    Glyco rod bearings (to be swain ppm coated)
    Glyco thrust washers (to be swain ppm coated)
    Durabond I/M shaft bearings (to be swain ppm coated)
    ARP main studs
    i/m shaft will be lightened, balanced and clearanced by scch-heads.com
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Re: popped the motor
    damn man, sorry to hear. what are your plans for it? i assume replace the block at least. maybe build the bottom this time?
    i dunno about those 60ft's man. you need to get those lower. you'd be in the mid to high 12's pretty easy with a 1.7ish 60...
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Veteran Member Three Rings prodrive's Avatar
    Feb 24 2006
    1999 Audi A4 1.8TQ
    Istanbul,Turkey
    Damn dude ,sorry to hear .. so you can built an ABA block now :)
    Just A4 ... A4 which we know
    2.0L - HTA35 - Cat3658 -Autronic EMS - Autronic 500R CDI etc..
    Feedback: Clicky
    97 A4 2.0TQM
    Rochester, NY
    yeah the 60ft's were pretty weak but i was still happy with the launches, since ive never really done it before. i think if i dropped the clutch a bit lower and spun less they might be a little better ( was dropping clutch around 6000 rpm)
    as far as the motor - i'm not sure yet. i guess i need to find out what's wrong with it first. it might just be something with the head/head gasket, if that's the case i'll just fix it.
    if the short block is bad, I have another one I can drop in for the time being and just drive the car easy until I can build one.
    i'm going to take the 2.8 transmission out and put the 1.8t trans back in, and install a smaller turbo (hy-35) next time though. my turbo is too big and falls out of it's power band, so I lost a lot there.
    97 A4 2.0TQM
    Rochester, NY
    btw...clutchnet gets a thumbs up, this clutch has 20k miles on it, and oil on it, and it didn't slip AT ALL
    Quote Originally Posted by pac1085 View Post
    i think i need to go abuse mine some
    contact via email please.
    97 A4 2.0TQM
    Rochester, NY
    do it!
    compression check just finished...
    155,170,180,0
    cylinder 4 is a goner. 3 had good compression but there was some oil in it too.
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    Re: popped the motor at the track today..
    Didn't anyone ever tell you to never say " Just one more run"!!!!!!!!!!!!!
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Veteran Member Four Rings 94jedi's Avatar
    Dec 07 2004
    Oly Platform, Pendlay bar, bumpers, squat rack, rings, Prowler
    Ocean Shitty Maryland
    Quote Originally Posted by quattro16 View Post
    dude, that's where legends are made and the cautious are forgotten.
    BTW, legends usually have their cars towed home lol...
    sorry to hear pac. get the motor rebuilt and get back out there!
    The harder I practice, the luckier I get.
    - Gary Player
    Dec 05 2007
    Not to get off topic, but may I ask if you changed your rods or were you running with the stockers in your BAT setup? I am doing searches for my future BAT setup and just wanted to see what made your motor blow. Your op said that you have a stock motor, but was just wondering if you swapped anything, as your sig says you are a BAt member though the thread says you are BT. Thanks!
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Sounds like you might have just blown the head gasket near cylinder 4 and it then started allowing oil into cylinder 3.
    If that is the case you were just pumping the oil right into the cylinders which ended up just going out the exhaust. Only way to find out is to just pull the head.
    97 A4 2.0TQM
    Rochester, NY
    Not to get off topic, but may I ask if you changed your rods or were you running with the stockers in your BAT setup? I am doing searches for my future BAT setup and just wanted to see what made your motor blow. Your op said that you have a stock motor, but was just wondering if you swapped anything. Thanks!
    no, the longblock is fully stock.
    after looking back at the data logs, i took 2ng gear to 7600 rpm. i also noticed that the coolant temp at that time was 240f
    97 A4 2.0TQM
    Rochester, NY
    no holes in the block, looks like there's oil comming out between cylinder 3 and 4 from the head gasket.
    Jul 07 2004
    socal
    Yeah if the coolant temps were at 240 degs the head bolts most likely stretched causing the head to lift. You also need to figure out why the coolant temps got so high, most likely a bad thermostat. I had the same thing happen to my turbo eclipse and it also sprayed oil all over the place when the head lifted.
    When you pull the head you will want to have a shop check it to make sure it didn't warp.
    Sep 17 2006
    SLC, UT
    ^wouldn't oil be coming out of more than just one place if the head did lift?
    Current:
    Previous:
    97 A4 2.0TQM
    Rochester, NY
    97 A4 2.0TQM
    Rochester, NY
    gotta give it to this car, i was able to drive it home 35 miles like that.
    Sep 17 2006
    SLC, UT
    haha, yep, it's totally a blown piston ring
    Current:
    Previous:
    97 A4 2.0TQM
    Rochester, NY
    should do the trick
    Sep 17 2006
    SLC, UT
    there is nothing that stuff can't do
    Current:
    Previous:
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    Now me and the mad scientist gotta rip apart the block, and replace the piston rings you fried!
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    Ouch. If you plan on sticking with stock bore pistons, you probably won't be able to use this block again, as all that detonation and scoring marks on the cylinder walls will more than likely have to be bored out. Luckily, larger bore aftermarket pistons are becoming much cheaper.
    "You know you have a bad idea when Ford guys are making fun of you."
    97 A4 2.0TQM
    Rochester, NY
    luckily I have another AEB shortblock which i'll be rebuilding
    Jul 07 2004
    socal
    Well dont worry your not the first to melt a 1.8t piston. I seen it happen to a few pistons on a 225TT which is said to have stock forged pistons.
    97 A4 2.0TQM
    Rochester, NY
    supposedly the AEB pistons are forged, and I'm planning to re-use the stockers in the other block (after having Swain coat the dome and skirts) but I'm starting to have second thoughts. then again, i've seen aftermarket forged pistons melt just the same.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    time to tear the bitch down, O-ring the block and throw some good parts in. BAT FTW :)
    I'll trade ya tranny's
    Sorry to hear about the engine, BAT on a stock block though, it was bound to happen sometime.
    I was always curious if the problem cyl would be #4 b/c it seems to pull timing before any other cylinder on all B5's
    Sep 17 2006
    SLC, UT
    btw, are you running any type of meth/water injection? your pistons look pretty clean for how many miles you must have on that motor
    Current:
    Previous:
    Jul 07 2004
    socal
    Quote Originally Posted by sean1.8t View Post
    Not keeping up with the AZ members?
    He tuned his SEM to run E85, but was running 93 octane at the track.
    Sep 17 2006
    SLC, UT
    d'oh! i totally forgot about him running e85..
    Current:
    Previous:
    Quote Originally Posted by djwimbo View Post
    the block didnt break though. his rods are still intact.
    the outcome would have been the same even w/ rods, given all other things equal.
    Apr 18 2007
    Orange Park, FL
    Quote Originally Posted by k0mpresd View Post
    Yeah, but that block is trash if he has no plans to go bigger bore pistons. I wouldn't be surprised if cylinder #4's rod is bent too though.
    Veteran Member Four Rings dualaudi's Avatar
    Dec 13 2004
    allroad 2.7t
    san diego
    hx35/40 - 13.2. Is a 30r bigger? What do you need for a 12.8 or lower?
    Give you props for BAT on a stocker. Makes me feel confident to upgrade from my gtrs to something bigger on my stocker.
    (sold) 1999.5tqm :: gtrs, atp 3"TP, tweaked mika t3/t4 8k, adj. fpr, forge 004, MBC, neuspeed: catback exhaust, E-bay special FMIC! 9"x28"x2.75" - SOLD
    https://www.instagram.com/dualaudi/
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    The block may still be fine, but that cylinder is not. Look at the top of the cylinder where the ring land burnt/broke away. Without measuring it I can't tell ya if it's FUBAR or not, it looks like a 82-83mm bore should be able to save the cylinder.
    97 A4 2.0TQM
    Rochester, NY
    Quote Originally Posted by dualaudi View Post
    it's a lot bigger than a 30r - it's a 72lb turbo - somewhere in between a gt35r and gt4088 - it is too big for my 1.8t and shitty tune - the turbo is capable of low 11's or hi 10's if it was on a car like Mike's. i fell out of it's power band almost every time I shifted
    97 A4 2.0TQM
    Rochester, NY
    it's really bad, i don't think even an 83.5mm bore would fix it. that's ok though because I won't be using this block , I have another one.
    97 A4 2.0TQM
    Rochester, NY
    i ran e85 for a few months, it cleaned everything out. even the fuel pump basket was bleeched white.. lol
    107,600 miles on the motor
    Jul 07 2004
    socal
    Plenty of people go 82-83.5mm so even if he doesn't use it someone else could.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Boat anchor?
    97 A4 2.0TQM
    Rochester, NY
    no way...
    (stolen from tomritt)
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Some people use tree-bases to hold up their Christmas Trees.
