    Apr 19 2008
    Utah
    Vag Com question for the experts!!
    Can someone tell me how to use vag com to disable the brake sensor warning light in the cluster?? I tried "shorting" both sides and it didn't work. I asked this same question on audiworld and got several douche bag responses, but nothing that could help me.
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Vag Com question for the experts!!
    I'm pretty sure you can't do it through VAG-COM. Any pictures of your jumper set up?
    Veteran Member Three Rings o3spec's Avatar
    Feb 07 2007
    Dover, DE
    just twist both wires together on both sensor harnesses. it will work. you must not have a good connection
    Account Terminated Four Rings
    Nov 30 2006
    01.5 pearl white S4 6speed
    annapolis, maryland
    Quote Originally Posted by o3spec View Post
    shut up
    Feb 07 2007
    Dover, DE
    go drive around in your supra you douche
