Results 1 to 6 of 6
    Senior Member Two Rings URSquattro's Avatar
    Jan 23 2007
    Waterwoooo, Ontario, Canada
    wheel size question, please help
    Hey guys, I have a 98 A4 1.8TQM and I just bought wheels for a really good price but now that I lok at them I have my doubts about them fitting????
    They are RS6 reps, Dimensions:
    5X112
    8.5 X 18" with an ET of 30?????
    will these even fit and if so, what size tire is my best choice??? 225/40 18 or 225/35 18??????
    '98 Audi A4 1.8TQM- APR 1bar,APR cat-back, ECS coil-overs, ECS RA4 steel FW clutch kit, 320MM Brembo BBK,RS6 18s, B&M SSK, Recaro S4 Front seats, HIDizzles, some gauges? always need more..
    'K4 GSXR600-with goodies-SOLD
    '94 S4 with goodies-RAPED/sold
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: wheel size question, please help
    should be fine. Stock wheels are ET35(IIRC) so you'll be just fine. I'd actually want a larger set like that to come in some to help clearance the fender.
    EDIT: on 18's I have no idea what aspect ration you should run. I know your overall tire diameter should be in the 24.9-25" range in order for your speedo to be correct.
    May 17 2007
    B7 QG avant
    Salt Lake City/ Park City
    I think 225/40/18 should be fine but go here and be sure
    http://www.1010tires.com/tiresizecalculator.asp
    - Colin
    Senior Member Two Rings stunner247's Avatar
    Dec 06 2006
    98 a4 2.0tq, 86 vw cabby, 91 V8 Quattro (sold), 98 328is, 1970 C10
    DC
    You should be good. I run 18x9 et35 with 235's and no problems
    Jan 23 2007
    alright sweet, thanks guys appreciate the help
    Feb 23 2004
    audi, vw, 72 bronco
    ne, pa
    they will pop out just a bit in the front 3mm atleast 225 would be safer all depending on what drop you have.
