Results 1 to 15 of 15
    Veteran Member Three Rings A4p's Avatar
    Mar 06 2006
    Audi 1.8TQM6 S-line USP 2004
    Sweden
    Car moves to the right
    Hi everybody.
    I have notice that, my car is moving to the right always when i let go the steering wheel, it's go the right direction... can anybody say what it could be??
    USP CLUB MEMBER 861
    Rev0 stage I file - 300+ bosch injector - OFE SS - APR Snub mount - Nitrogen - RS4 Swaybar - K&N air filter - **-
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: Car moves to the right
    It is your alignment... any reputable dealer or shop can do an aligment for you
    Veteran Member Four Rings A4TUNE's Avatar
    Sep 14 2006
    Mass
    yep, alignment. or unevenly worn tires maybe.
    -Max
    2004 A4 1.8T M6 Quattro Ultrasport
    REVO Stage 1 | AWE Boost Gauge | Carbonio CAI | Valeo Single Xenon Black Ecodes | RS4 Rear Sway Bar | 18x8 OZ Superleggera | DTH USP Splitter
    Veteran Member Four Rings JJPA4SE's Avatar
    Boxes
    Pittsburgh, PA
    check tire air pressure on all four corners before dropping $100+. Also keep in mind that some roads are slightly sloped (to the right) for water runoff...
    2001.5 S4
    2005 Acura RL - SOLD
    2006 S4 - 25quattro #159 - SOLD
    2005 A4 1.8tqm Ultrasport Avant - SOLD
    2005 A4 1.8tqm Special Edition - SOLD
    Mar 06 2006
    Sweden
    isnt Balancing and aligmemt the same??
    I Was at the audi dealer 2 weeks ago, and i told them that the car moves to the right, and whe took a test drive, and he told me that it is the road, that cause the car to move to the right, but i told him that it was the car not the road... they took the car in and changed all 4 tires to michelkin sporty and balanced it and all that, but it still goes to the right??
    USP CLUB MEMBER 861
    Boxes
    Pittsburgh, PA
    find a back road and drive on the wrong side (at your own risk) to see how it pulls and which way.. that'll tell you if its the road...
    Balancing = tires
    Alignment = suspension components
    2001.5 S4
    Mar 06 2006
    Sweden
    I have tried many differince road and it still goes to the right. ive also tried to turn, the steering wheel to the left and it goes to the right.
    USP CLUB MEMBER 861
    Veteran Member Three Rings Noodle's Avatar
    Oct 16 2007
    Pittsburgh, PA
    Chances are it's an alignment/balance combo. As someone mentioned before, check the PSI on the right wheels first. If they're less, it will cause it to pull.
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Quote Originally Posted by A4p View Post
    I don't think you understood what he was trying to tell you. When you drive the right direction on a road that is sloped slightly (blind to the naked eye) to the right your car will pull right. So drive the opposite direction on the same side of the road (against traffic) on an empty road and if it still pulls right, you need an alignment; if it doesn't, it's the road.
    Veteran Member Three Rings b6a4's Avatar
    Oct 09 2006
    Asheville, NC
    it could be your grammar...
    __________________________________________________ __________________________________________________ ____________________
    2001 Audi S4 Avant. Black/Blue Sport. SRM K24 Hybrids. (Totaled)
    2017 Audi Q7 3.0T
    2010 Audi Q7 TDI(sold)
    Boxes
    Pittsburgh, PA
    Quote Originally Posted by akaEsCo01 View Post
    yes... if it pulls left while driving the wrong way (other side of the road) then your alignment is good if it drives straight i would think the alignment is bad (the road pulling left and the car pulling right = straight)
    2001.5 S4
    Registered Member Two Rings LateApex's Avatar
    Apr 10 2008
    Blk/Blk B6A4 TQ 6M
    Alb, NY
    You may want to move the steering wheel back and forth quickly to see if there is any slack (there should be none at all). If there is then you may need to check the steering arm components (possibly bushings). If your dealer does an alignment then it will not correct this because the play in the front wheels would still cause unwanted toe changes (wheels not staying where the alignment put them because it's loose). Also, I beleive the balancing you're talking about is only relevant to how the tires sit on the rim and is not the same as an alignment of your suspension components. It is possible you have a bent rim (unlikely) or even a bent link or worn bushing somewhere else in the suspension that has some slack in it too. Take it back to the dealer and ask them to check for unwanted slack possibly caused by worn bushings. Good luck!
    Registered Member Two Rings 05a4flip's Avatar
    Oct 09 2007
    Atlantic City NJ
    9 times out of 10 alignment or tires with uneven wear.
    Mar 06 2006
    Sweden
    Quote Originally Posted by LateApex View Post
    I think that may be the problem. I will copy this and show them what you have righted. if that is okay?. also i am still under warranty so no paying :)
    USP CLUB MEMBER 861
    Apr 10 2008
    Blk/Blk B6A4 TQ 6M
    Alb, NY
    Thats ok with me but I'm no professional mechanic haha. Just trying to offer a suggestion that hadn't been given yet.
