Results 1 to 13 of 13
    Dec 24 2007
    St. Pete,FL
    2002 APR Stage 1+ with 380cc injectors???
    or do i really need to find some tt225's? i found a deal on some 380's but i just wanna make sure the apr 1+ will work with them....
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    Re: 2002 APR Stage 1+ with 380cc injectors???
    The ones that come with the program from APR are Bosch 386cc I believe, so 380's should be fine. TT225's also work too.
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    May 26 2005
    CLS63tt
    Boston
    the bosch 386 are the tt225s and 380 will work on giac and revo, not apr
    Jan 28 2007
    dallas TX
    I believe you can use the siemens ones i think....
    Dec 24 2007
    St. Pete,FL
    i saw somewhere on here that only with the MY 2002 the 380's wont work and you need 386's.....just looking for some good clarification so i can pull the trigger on this deal
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Im pretty sure you can use usrt 380's but not bosch 380's...has to do with the spray pattern
    Mar 27 2005
    The Cold North
    the Bosch 386cc ones run properly with the APR 1+ software. That was the injector APR designed the software for and it has the proper spray pattern for this motor. GIAC has a couple injectors they can run (more flexable).
    Honestly you can run what ever upgraded injector you want with the 1+ software, just don't expect it to run properly. I am always amazed why people insist on running non-compatible parts to save $50. Do it right the first time, especially on important things like injectors.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Sep 24 2007
    Woodbridge, Ontario
    Quote Originally Posted by EBG 18T View Post
    Yeah, you need Bosch 386, not the cheap 380's
    Veteran Member Three Rings AudiAdi's Avatar
    Jul 06 2007
    2020 Toyota 4Runner TRD PRO || 2016 Honda Pilot Elite AWD
    Bellevue, WA
    bosch 386 cc = tt225 injectors. And yes, you need them to run the APR program properly.
    USP CLUB MEMBER #78
    2005 Audi A4 1.8T Quattro 6M K04 - GONE
    2010 Audi S4 S-Tronic ADS Lite
    Senior Member Three Rings trailboss's Avatar
    Oct 31 2004
    04 usp 1.8t, 99 1.8t gtrs
    Lansdowne VA, Waldizzle, MD
    yeah you need them alright
    I run genessis 380cc injectors, they work fine and hve to had a problem for 6+ months. The injectors you want are either tt225 injectors or genessis 380cc injectors. Now make sure you get approved for the loan on tt225s, they are ~$400 or genessis 380cc $250. And the guy that said do things right for $50, well my freind the search function is your freind, and its normally a $100 difference, for something that works just as good.
    Mar 27 2005
    The Cold North
    Quote Originally Posted by trailboss View Post
    You are right, the search is your freind.
    Many 2002 models had fault codes when trying alternative injectors. The Genessis 380cc model was one of the ones that works most times, but not every time. The 2002 model was a very particular car. APR went thru several interations of the software to make sure the TT225/Bosch 386cc injectors worked properly. Then again i am sure you already knew that. Your car may run fine on the 380cc genessis injectors, but can you garantee his will? Or when/if he has an issue are you going to help him out when APR tells him to buy the right injector to run their file?
    If you had a 2002 model year are you going to risk buying injectors that don't always worked with the APR software to save a couple $$'s. I doubt it. But then again maybe you could spend $250 and get lucky. Or then again maybe not.
    As for the $50 comment, so what. $50, $100. Who cares. It is chump change in the big picture. TT Injectors can easily be had for ~$80/each.
    2020 Chevy AEV ZR2
    Oct 31 2004
    Yeap, i have searched and ill do some for you since i guess you may have not
    http://www.audizine.com/forum/showth...2002+lean+code
    Look through that thread, how many 02's there are using tt225 injectors and have gotten codes.... I think i counted 7-9 something like that looks like the tt225 are the right answer
    Im not saying genesis injectors won't but i have not had a problem nor have many othere people.
    Mar 27 2005
    The Cold North
    Oh might trailboss master and god all knowing. I bow down to you.. I wish all knew as much as you..
    But I am not going to continue debating this with you. The OP asked if the 380's are going to work. The answer is maybe, you and i both know this. But Atleast if you have the issue with the TT225 injectors you can go back to APR and get assistance, good luck with getting assistance with the wrong injectors.
    2020 Chevy AEV ZR2
