Results 1 to 16 of 16
    Senior Member Two Rings B6_Rakete's Avatar
    Apr 17 2008
    '04 S4 Avant 6sp, '06 330i 6sp
    Strut tower braces for B6 S4?
    I notice a small bit of flex in the front end of my B6 S4 Avant when it's driven at the limit. It would probably serve the suspension mount points to be stiffened by way of a strut tower brace, but no one seems to make one for the car (not that I could find anyway).
    Do these exist for the B6 platform?
    Veteran Member Four Rings Monchichi8's Avatar
    Jul 03 2004
    2004 S4, 2005 Grand Cherokee Hemi
    Boulder,Colorado
    Re: Strut tower braces for B6 S4?
    Anybody know??..
    Veteran Member Four Rings Eddie Man's Avatar
    Nov 05 2004
    Detroit/Clarkston
    Sport Suspension & S4's (B6 & B7) already has a strut bar.
    2006 S4 Avant
    dolphin gray | 6speed | alcantara | premium | cold | bose | sirius | navigation | bluetooth | parktronic | ebony | carbon fiber
    >>> Got Mods?
    Apr 17 2008
    I must be blind, I'll look again.
    Nov 04 2009
    Falls Church, VA
    i found one for b7. i hope we can use this for b6 as well. just check out the link. they look pretty nice too..
    http://www.europeanperformanceproduc...004-2007-.html
    Sep 13 2008
    Western Chicago Burbs
    It's the black squareish piece of steel that runs right behind the secondary firewall. (or is it called primary since it;s the first one? the one between the engine and battery)
    Senior Member Two Rings KMAzz's Avatar
    Jun 03 2010
    2010 Nissan GTR, 05 S4, 03 A4
    Bethlehem,PA
    Quote Originally Posted by pradheep88 View Post
    It looks nice but the way the bar mounts is the reason I wouldn't use that bar for anything but to make the eng bay look better. The only strut tower bars i'd use would be solid bars or if those aren't an option a bar that isn't hinged.
    Senior Member Two Rings rxbike's Avatar
    Apr 01 2009
    04 b6 s4, 07 toy tundra dc
    CA
    If someone designed a three point strut bar then it would be worth it. The lateral bars out there are junk in my opinion. To do this right, you need to triangulate the struts to the firewall to really tighten up your chassis.
    2004 B6 S4 black on black. VMR RS4 reps wheels, APR down pipe and exhaust, JHM tune,JHM intake manifold and throttle body, JHM lightweight pulley, Snub Mount; Eclipse AVN 726E nav/dvd unit. AR slot/slot/dimple rotors
    2003 Porsche 996 TT EPL stage 1 tune, AR Design 3" xflo street exhaust, Clutch Master 3600lbs clamp force/LWFW
    2000 Porsche Carrera C2 Schnell Header/Exhaust , Schnell Cold Air, 19" SSR GT-3
    2007 Toyota Tundra 5.7L doublecab TRD intake
    2003 VW GTI 1.8T APR stage 1
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Non-solid endlinks = no thanks
    Veteran Member Four Rings LJH's Avatar
    Oct 03 2006
    '84 Ur-q, '04 S4 6MT, '08 Outback XT 5MT
    Quote Originally Posted by B6_Rakete View Post
    Really......If you can really feel that I would start looking at doing solid suspension/subframe bushings etc. When I was younger I did a lot of SCCA Auto-X and HPD's and in both my C Stock prepared MK1 MR2 and my Ur-q I really could not "feel" any benefits of strut braces. I also believe that how Audi has designed both the B5 and B6 with 2 firewalls the strut towers are very well located. While I have not done a lot of Auto-X and track time in recent years I still enjoy my Sunday morning jaunts and I have never felt that the chassis was flexing.
    my $0.02
    Cheers,
    Jim
    Senior Member Three Rings alwaysaudi's Avatar
    Mar 11 2008
    2008 RS4, 2011 A3 2.0T Quattro, 73 MG Miget, 87 325is Chumpcar, 2000 323i SCCA racecar
    VIR
    I had a OMP strut tower brace on my B5 auto-xer and could def tell a difference on and off. But to me the B5/B6 are different beasts, I feel like any more stiff in the front on my B6 and it will just wash out. I still think my B5 was more nibble and used the strut tower brace very effectively. I think it all depends on the other aspects of your suspension, and set up.
    2008 Ibis RS4 Titanium package - Milltek CB - Stasis MS - H-sways F&R - EBwerk droplinks - JHM R3 clutch + LWFW - JHM LW Crank pulley - JHM IM spacers - Roti SNAs with 275 Supersports
    Apr 24 2009
    Frisco, TX
    I suggest a larger rear sway bar if you are dissatisfied with the handling.
    Established Member Two Rings S4_25quattro's Avatar
    Feb 08 2012
    1989 928 GT, 2013 C63 AMG Coupe, 2015 ML350 Bluetec tow mule, 2001 IS300 & 2003 C5 Z06 race cars
    Toronto, Canada
    Thumbs up
    Quote Originally Posted by dparm View Post
    +1 on the stiffer rear sway bar idea if you haven't already got one. It made a noticeable difference on my B7 S4 when pushed.
    Veteran Member Four Rings event's Avatar
    Jun 21 2009
    OR
    As stated above "sport" B7's have them.
    If you want more rigidity, maybe call up the guys at Ultra Racing and see if THESE will work. The mounting points should be the same.
    Apr 24 2009
    Frisco, TX
    I still don't understand the OP's point...how can you "feel a bit of chassis flex at the limit"?
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    May 24 2010
    2004 S4 6spd
    Dougalsville, GA
    Quote Originally Posted by event View Post
    i made the mistake of buying this....do not buy it. it does bolt up, but it seriously conflicts with the coolant tank.
    JHM 93 Tune w/ LA ** Piggies ** Magnaflow catback ** V1 Hardwire ** Podi V1 Gauge Remote Display ** A Beagle in the Back Seat ** K&N drop in ** Porsche 6000k low beams ** 3000K Fogs ** JHM Delrin Weighted Shift nob ** stern motor mounts ** stern trans mount ** Apikol snub ** 034 zero clearance snub bracket ** IM spacers ** Cupra R lip ** Thule 480 Roof Rack With 44" Fairing ** Super Blue DOT4 Brake Fluid
