2004 B6 A4Q with 59K miles
worn brake pad light came on yesterday, I'll be changing my pads tomorrow.
Just eyeballing the pads with the wheels on, it looks like the rear pads are thinner than the fronts. Rotors look/feel fine (pretty smooth only very light grooves, no pulsing grinding at the brake pedal.
1) Will I be able to tell by eyeball which pads (front or rear) need replacement? Is there a pad wear line I'll be able to identify or minimum thickness spec I could measure?
From my searches I got that I may need to open up the brake fluid reservoir to spill off some fluid as I push my pistons back in.
2) should I open the brake fluid reservoir before I start pushing the rotors back in?
3) If I can push the piston back in with the brake fluid reservoir cap shut, what will be the sign that I need to open it to spill off fluid (resistance in the rotor, fluid leaking from the cap?)
4) I gather that I can open the brake fluid reservoir cap to spill off fluid (or top up fluid) as necessary without needing to bleed the brakes, correct?
If the fluid is brown and mucky then I'm up for a brake bleed as well.
5) If I have to bleed the brakes how much fluid will I need to buy to get the job done?
I've got the new pads (front and rear to be safe, I know I'll need them both eventually), caliper kit, micrometer, stands and all the hand tools needed and am pretty mechanically inclined, at least I can follow DIY instructions pretty well.
If possible, I'd like to avoid getting into bleeding the brakes as part of this job. If the general recommendation is tough s**T, best practice would be to bleed, I'll be on my way down to the parts store to buy a brake bleed kit.
Any insight the more experienced forum members could provide would be appreciated.
Thanks,
Matt
