Results 1 to 7 of 7
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    APR - ESP and ABS
    I bought my B6 S4 about a month ago and few days later I figured out it was flashed with APR already. I've had APR before so I tried the cruise control and sure enough CEL started to flash multiple programs. Finally today I had a chance to go have it scanned to see what is on there and I found Stock, 91, 93, Valet and security lockout.
    Anyway, I switched to 93 program and started the car but my ESP (ASR) and ABS are nor turned off (lights were on and stayed on). I have not seen this before on any other APR car although my experiences we always with VW's. Anyone got the same thing?
    I'll have to wait until Monday to call APR and see if they know what's up.
    Established Member Two Rings CasaS4's Avatar
    Dec 14 2006
    Atlanta, Ga
    Re: APR - ESP and ABS
    Typically if those 2 (ESP and ABS) lights are on simultaneously, it means that something is wrong with the MAF sensor.
    I would recommend that you scan the codes.
    Mar 24 2008
    khgkhg
    The lights are on only when APR is on. If I put it back in stock mode they don't come on.
    Dec 14 2006
    Atlanta, Ga
    Until you scan the codes, there isn't any advice that we can give you. Did you do a throttle body alignment after you got the new software?
    The stock mode is still an APR program, its just coded to replicate the behavior of the factory software.
    Jul 21 2004
    South Florida
    PUt the car back in "apr mode" and if the lights are on then turn the car off and start it back up again. If they go away, all is fine. If not, get it scanned.
    2018 Audi S5
    Gone-
    Mar 24 2008
    khgkhg
    bhvrdr wins again. There were no codes either.
    Jan 14 2008
    B8.5 S4 - 6MT Sepang/Panda
    Calgary
    This happens to me every single time I switch programs. I always have to turn it off and on twice. I also don't get the flashing lights for confirmation when I start up again, but she revs to 7500 still, so I know it's working.
