Results 1 to 12 of 12
    Saint Cloud, Fl
    Apex'i AVC-R........ help
    - Okay I have everything wired up, but I have no idea how to set up the solenoids. I dont understand the plumbing of our cars.
    - any help would be greatly apreciated.
    - Yes I have searched !
    instagram ------------> low_enforcement
    Aug 26 2005
    Re: Apex'i AVC-R........ help
    First, do you have the instructions for that controller?
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    go to page 42 for what you need
    If its a internal wg setup
    NO port = inlet - from turbo
    COM port = outlet- to wg actuator
    External wg setup
    NC port = inlet - Y connector with 1 hose to turbo, 1 line going to side port of WG and 1 line going to NC port
    COM port = outlet to top of WG
    Instructions for this EBC is just like the one for the Greddy profec B spec 2.
    Saint Cloud, Fl
    okay got the it all hooked up, but I cant boost past 5lbs
    Aug 26 2005
    Quote Originally Posted by 7speed View Post
    Can you describe how you connected the solinoid valve? The hose from the compressor housing, should be connected to the solinoid valve "Common" port, and the N.O.* port connected to the wastegate actuator.
    If the wastegate actuator is connected directly to the turbo compressor discharge hose fitting, the maximum boost will only be about 5 psig. The stock N75 raises boost higher, by venting some of the pressure in the hose to the wastegate actuator, preventing the wastegate from opening until the boost pressure is at the level specified. The Apex'i works about the same way, by venting some of the boost pressure in the hose to ambient outside pressure, depending on the duty cycle of the control voltage applied to the solinoid valve, the wastegate "sees" only a partial amout of the pressure at the compressor discharge, until the boost pressure is at the presssure specified. Then, the control reduces the amount of air vented, increasing the control boost air pressure sent to the wastegate actuator, opening the wastegate to limit and control the boost pressure from the turbo. Capisce?
    * N.O. = "Normally Open", N.C. = "Normally Closed", where "Normally" means NOT energized or powered ON, and "Open" "Closed" flow paths to the Common port.
    Saint Cloud, Fl
    Do you have an Avcr in your car ?
    - Im not sure that i have it wired correctly. There ar 2 purple wires coming from my ECU cable, which Purple wire did you use ?
    - Also I am not sure if I have the Solenoid in the correct location, I have it t'd in from the manifold
    Aug 26 2005
    The valve should be where the original N75 was located or near there. Not tee'd from the manifold. Either the flow path from the manifold via the solinoid valve is connected such that the valve can't effect the pressure sent to the wastegate, or the valve is not energizing and therefore not venting any control air pressure signal to the wastegate actuator, thus the low boost pressure determined only by the balance between the actuator spring tension and the control boost air pressure from the compressor housing.
    Aug 26 2005
    The Purple wire from the Apex'i controller, is connected to the engine speed sensor, or alternatively, to one of the injector low side wires.
    Have you downloaded and reviewed the instructions linked from "mike-2ptzero's" post above?
    Saint Cloud, Fl
    YESSSSSS ! Problem solved. I had the n75 unplugged. I plugged it up and now everything is perfect !
    Thanks
    Jul 07 2004
    socal
    Thanks
    Good to hear.
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    Wink Re: Apex'i AVC-R........ help
    External wg setup
    Howd you know that mike?
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Veteran Member Four Rings AudiHere04's Avatar
    Nov 21 2005
    568HP%20FWD%20A4
    East Coast
    External wg setup
    Do you plug NO port?
    Buy My Parts!
    Precision 6262 Turbo needs a core - $800
    B6 Thule Evo Roof Rack - $300
