Results 1 to 14 of 14
Thread: Boost Problem
    Established Member Two Rings zackcamp's Avatar
    Jan 14 2008
    81 Rabbit Diesel, 91 GTI VR6t
    Virginia Beach, VA
    Boost Problem
    So I've always thought my car was a little slow, so I've been slowly upgrading to try to improve on that. I installed an AWE turbo gauge last weekend and at the beginning every seemed over. Vacuum was reading around 17-20, right where AWE says it should be. So I take it out on the road to test it out.
    To get to the point, I 'm peaking at 10psi in about 3rd gear and the needle will not climb any higher. From what a buddy explained to me, the needle should drop down in vacuum and then shoot up and start registering boost, none of which my car does. It just slowly starts climbing out of vacuum into boost. As far as engine modifications, I have APR stage 1, carbonio intake, and APR DV, just basics.
    Does this sound like an engine issue or a gauge issue? I installed the gauge exactly by the directions and the vacuum is reading right. I ordered all new vacuum hose, as well as Forge TIP, and Samco hose hit just incase its a leak.
    Im originially a VR6 guy, so this whole stock turbo thing is tripping me out.
    Any help would be appreciated
    Pic for fun
    Dec 06 2007
    Re: Boost Problem
    deffinately a problem, ur supposed to hit about 17PSI and hold 15 with stage 1! run a boost leak test!
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    Re: Boost Problem
    Quote Originally Posted by AudiA4Turbo22 View Post
    What does your gauge read when the car is off? It should read 0
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Dec 06 2007
    Re: Boost Problem
    ^^don't have a guage installed yet LOL! sitting in my room awaitin!
    -Kirk
    Veteran Member Three Rings TurboQuattroPwr's Avatar
    Sep 28 2006
    Delaware
    Re: Boost Problem
    It would probably be wise to run a boost leak test.....
    Check out http://www.a4mods.com/ for a write up on how to check for a leak and some other cool DIY's.
    Good luck!!!!
    ~To the above question: My guage reads 0 when the car is off, vac is 20-22 and boost has been holding 20-21 on GIAC +1.
    2018 Audi S4 3.0T
    18% Tint, CquartzPro Ceramic Coating
    2002 Audi A4 1.8TQM *Gone*
    Jan 14 2008
    Virginia Beach, VA
    Re: Boost Problem
    gauge sits at 0 when off. The car just feels so sluggish. Im going look into the boost leak test. Thanks a lot guys.
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Re: Boost Problem
    Quote Originally Posted by zackcamp View Post
    Heat soak.
    Jan 14 2008
    Virginia Beach, VA
    Re: Boost Problem
    Quote Originally Posted by audipotential View Post
    Heat soak.
    wha...?
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    Re: Boost Problem
    bad splitter.
    Jun 30 2007
    Raleigh, NC
    Re: Boost Problem
    ^heat soak won't make you loost boost. 10psi isn't high enough for a stage 1 car.
    my money is on a bad DV. R1's are notorious. go pick up a 710n from the stealership and swap out your apr DV to see if it's bad. from there you can either leave the 710n in the car, try and get a new DV from apr, or get a baileys/forge/etc etc etc.
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Veteran Member Four Rings Smiley's Avatar
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Re: Boost Problem
    Can a Bad o2 sensor cause lower boost?
    Im 1+ and i spike 14, hold like 10 ..
    Jun 30 2007
    Raleigh, NC
    Re: Boost Problem
    Quote Originally Posted by GtiRSmiley View Post
    if it's the primary o2 it can cause more problems than that
    The Awesome™
    Feb 24 2004
    Land of the smiles
    Re: Boost Problem
    before you start replacing parts why dont you vag the car and check for codes.
    Established Member Two Rings busakiller's Avatar
    Dec 18 2007
    Pittsburgh,PA
    Re: Boost Problem
    Pic for fun
    Ever find out what the boost problem was?? And do you have anymore pics of your car w/ ur RS6 wheels.. I'm looking to get a set...
