Results 1 to 37 of 37
    post your oil cooler set ups.
    would like to see a few.
    contact via email please.
    Jun 04 2004
    fairfield cnty, CT
    Re: post your oil cooler set ups.
    S4 oil cooler :)
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    hey mike, post up my pics when you read this thread.... im too lazy to do it myself lol
    Quote Originally Posted by ModifiedA4 View Post
    S4 oil cooler :)
    did you notice a change in temperature?
    Jun 04 2004
    fairfield cnty, CT
    Quote Originally Posted by k0mpresd View Post
    yup...less highs, basically more heat capacity. and combined with the manual fan mod, i can dump a ton of oil heat out through the coolant system.
    fan mod?
    edit: nevermind. found it.
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    NH
    efk w/ a manual switch?
    Jun 04 2004
    fairfield cnty, CT
    fan mod?
    yah for cooldowns, the A/C condenser fan rigged to run on high when i want.
    http://www.modifieda4.com/web/tech/fan-mod.html
    i edited my original post but thanks for the link
    Jan 17 2006
    Cali
    Here's a write up I did on another forum, everything you need to do it. PM me if you have questions.
    http://www.passatworld.com/forums/sh...d.php?t=215363
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    anyone know if a trans cooler can be run for a tip?
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Quote Originally Posted by JaVa View Post
    from what I hear, it wont do anything.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    You already have one! It runs through the radiator.
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Jan 07 2007
    Quote Originally Posted by quattro16 View Post
    thats what i gought but didnt see any obvious lines last time i was down there. why wouldnt an external cooler do any good. i know my tranny tunnel get fricken hot to the toutch after a good drive.
    Oct 27 2007
    In the lab
    oh ill show it off
    Oct 25 2006
    '98.5 A4 1.8tqm Sport, '01 MDX
    Oxford, CT
    Quote Originally Posted by 317ssayzarc View Post
    oh ill show it off
    That's slick - is that a kit or did you piece it together?
    Senior Member Three Rings Mad_Audi's Avatar
    Mar 06 2006
    97 Amulet Red Audi A4 1.8T
    Greenville, NC
    ^^badass son. gg.
    Oct 27 2007
    In the lab
    Quote Originally Posted by ct1.8t4me View Post
    its a ER fmic of course and heres the oil cooler setup: derale core from jegs (its a rebadged setrab which is the nascar/ferrari brand), 2 90 degree -8AN fittings, 2 -8AN straight fittings, 20' of Jegs pushloc hose -8, and a Mocal thermo plate
    so i got the super score.
    we happened to have a pd oil cooler laying around the shop.
    far right. 4cyl left, v6 middle. hopefully it fits.
    Jun 04 2004
    fairfield cnty, CT
    nice, thats also the toureg oc.
    uh oh. im a little nervous now. im not sure how i feel about a touareg part on my car. haha. oh well.
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Mocal sandwich adaptor plumbed to a BMW E30 M3 oil cooler.
    Link for more info
    http://forums.audiworld.com/a4/msgs/2380083.phtml
    Jun 04 2004
    fairfield cnty, CT
    I like that setup Mike, its alot like the RS4 OC.
    well, it fits.
    Oct 25 2006
    Oxford, CT
    So - I was wondering. When the oil temps start creeping toward 250 is that from the increased water temps or the oil itself?
    I guess what I am getting at is, would there be benefit to just adding a sandwich style adapter to the existing setup? This way, you would benefit from the quicker warm up of the oil from the engine coolant, but then increased cooling and capacity from the cooler. This is all assuming there is no thermostat in the sandwich or anywhere else.
    Any thoughts?
    Oct 27 2007
    In the lab
    I completely eliminated the cooler because they fail... I didn't want to deal with that, ever...
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by Mike@PureMS View Post
    Would that fit up by the hood grille instead of the lower so I can run a FMIC too?
    Jun 04 2004
    fairfield cnty, CT
    Any thoughts?
    you are hitting the nail on the head. in fact the RS4 oil cooler has both parts.
    -the actual A4 sized heat exchanger
    -an air/oil radiator up front like the bmw one mike posted
    that is probably the best setup for a cold climate/daily driver + track car.
    Oct 25 2006
    Oxford, CT
    That is what I am shooting for. I am scouring Ebay for unique and random oil coolers daily. I am finding everything from military surplus oil coolers from aircraft, cessna oil coolers, motorcycle oil coolers, etc.
    I plan on getting a nice and unique unit on there and coupling it with a regular sandwich adapter, while retaining the stock cooler setup.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Where do you guys tap into for the oil pressure to the cooler? Pre or Post Oil filter?
    I haven't seen any pics of where the lines come from, just the coolers themselves.
    And I'm a little lost as to when should I upgrade my oil cooler? I've never seen my oil temps get any higher than ~220 on the stock gauge, but that's on a long drive 150+miles.
    Oct 27 2007
    In the lab
    Heres my order from JEG's, and a Mocal plate from Issam and your all set
    QTY Part #
    1 259-51008
    2 555-110052
    1 555-102023
    1 555-53500
    2 555-110072
    Quote Originally Posted by djwimbo View Post
    if you do anything w/ your car other than just drive it i dont see it being a bad investment.
    most ppl on here that have them seem to either road race or drag race.
    i started using motul oil recently. this year i noticed my oil temps a little higher than what they were. i didnt like that. so i went in search of a solution. no real reason other than i just wanted to.
    Veteran Member Three Rings leon's Avatar
    Nov 28 2004
    A4 1.8T Quattro/VW Polo 6N
    The Netherlands, Europe.
    @317ssayzarc:
    How did you mount this cooler? I dont see any bolts?
    A4 1.8T QUATTRO
    Garret GTRS turbo/Forge DV007/Bosch 440/Bosch 044 fuel pump/HT 3" SS TIP/HT 4" SS MAF/Autobahn FMIC/Carbonio CAI/Racekat/2.5" SS HT Exhaust/Eisenmann Muffler/034 High Flow manifold/Mocal plate,Setrab oilcooler/Porsche Brakes/Eibach Pro Street S/19"BBS Le Mans
    Veteran Member Three Rings 1NaudiA4's Avatar
    Feb 13 2007
    98 A4
    Chicago
    Parts used:
    1- Mocal Sandwich plate with 180* thermostat
    1- Earls Performance 5"x8.25"x2" Oil cooler pn EAR-21610ERL
    1- 3/4" x 16 Nipple
    5'- 10an stainless braided hose
    1- Straight 10an hose end
    1- 45* 10an hose end
    2- 90* 10an hose ends
    2- 10an flare to 1/2" adapters
    Its hard for me to get a good picture of the cooler since its hidden behind my intercooler pipe. I'm probably going to fabricate an air duct before the summer so it will get some good air flow.
    Oct 27 2007
    In the lab
    Quote Originally Posted by leon View Post
    @317ssayzarc:
    3M clear dual lock velcro. The car has been over 120mph with no bumper and the cooler is still tight on there.
    http://i7.ebayimg.com/06/i/000/ag/9e/40de_1.JPG
    Nov 28 2004
    Thx.. Will do this with my Setrab..
    A4 1.8T QUATTRO
