Results 1 to 3 of 3
    Registered Member One Ring JZA's Avatar
    Mar 29 2008
    Bay Area
    b6: Possible adapter for a different offset?
    I have a set of Breyton rims from my dads BMW 528. We tried to put them on my B6 quattro but the offsets do not match.
    A friend told me there was a bolt on adapter of some sort that would allow me to use a different offset on my car. In this case they would be my Breytons. Is this true?
    Any help greatly appreciated!
    Jun 14 2005
    Anaheim, CA
    Re: b6: Possible adapter for a different offset?
    Hi,
    The offset is already too low for your vehicle. The wheels are probably around a +15-20 offset. An adapter is just going to make it lower since it pushes it farther from the hub to accommodate for the 5x112 pcd. Your vehicle requires around a +35-40 offset for a 8.5" wheel.
    -Charles@VMRWheels
    Brandon @ VMR Wheels
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Yep, you would need something pretty thick to make that work. H&R makes very good hub centeric spacers., you may want to call them for thier opinion.
