Originally Posted by
Dos::Avants
Yeah, Basta!
Do you have a personal lift that you bought or have access to a shop? I always dreamed about having my own personal lift, but my garage sits below a room so the ceiling is too low. Next house, if it ever happens, I am definitely going to invest in a lift....
Thanks COAVANT!
Sorry to stick my tongue out at you guys... My friend built a garage with a lift so I just drive 10mins over to his house to do my work. I'm very fortunate to have this at my disposal. It makes life 10x easier. Every task is a breeze now
. Esp when I had to swap my stock exhaust back on last December. Took all of 20minutes.
There are some photos of the garage here:
http://www.audigeeks.com/forums/inde...20948#msg20948
Its now fully heated, insulated and sheetrocked.
Back on topic.....
When I'm at home (as when I pull my motor in a few weeks), I do pretty much exactly what John describes here:
diagnosticator
Placing the jackstands at the jacking locations directly forward of, or directly behind the floor jacks, is problematic due to space issues. This is why I place the floor jacks at the jacking locations, a floor jack on each side, alternately operate each jack to raise the front end of the car, then position the jack stands directly under the subframe to body mounts. Lower each jack slowly to load the jack stands, then move the jacks to the rear and repeat. The subframe mounts used are the two rear mounts in the front, and the two forward mounts in the rear. A weight force spreader pad must be placed between each jack stand and the subframe mounting to ensure stability. Using a tight grained hardwood pad works well, provided the pad does not split from the load. A 1" to 2" thick, by 6 inch diameter round hardwood pad with a 1 1/4" hole in the center to provide clearance for the subframe mounting bolt head, is ideal.
I place the jackstands exactly where John mentioned.
I carefully make sure the jack stands are seated well on the car and have a piece of wood between the jackstands the and ground to prevent sinking into the asphalt. I don't place wood in between the jackstands and car but its a good idea. Good idea from being extremely safe and having the car completely supported evenly.
I accomplish this with one floor jack and its kind of sketchy at times but I take my time and the car eventually gets evenly supported. Probably takes me 30min or more to get the car supported safely with one floor jack.
