Results 1 to 10 of 10
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    Bose/Non Bose Symphony
    I'm buying a Symphony from a member on here, and it came from a non Bose equipped car. My Audi came with the Bose system. Are the decks the same part number? Will the deck from the non Bose read "BOSE" when turned on and function accordingly when plugged into my car? Or are these two separate decks?
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    May 19 2007
    Bay Area
    Re: Bose/Non Bose Symphony
    Quote Originally Posted by a20c.net
    All standard Audi headunits can be coded to work with the Bose sound system, there is no such thing as a Bose Symphony and a non-Bose Symphony.
    Can anyone confirm this? Is "coding" the unite as simple as plugging it in and letting it figure it out on it's own?
    SIXFIVEOHphoto
    May 19 2007
    Bay Area
    Anyone?
    SIXFIVEOHphoto
    May 19 2007
    Bay Area
    Nobody?
    SIXFIVEOHphoto
    Veteran Member Three Rings prey's Avatar
    Feb 03 2007
    2003 Audi a4 1.8 TQMS
    Parsippany
    U have to change it to non bose through VAG, because the BOSE system amplifies the sound through the black amplifier in the trunk, if u have seen one. While, the non bose mode pre-amplifies the sound before it goes to the speakers. So, if u just hook it up, it will work, but the sound will be crappy as hell.
    Ti-kan's website has the instructions and the code to make it non bose.
    good luck
    Prey
    Prey
    2003 Audi a4 1.8TQMS Unitronic Stage 1+
    May 19 2007
    Bay Area
    I think you read my post the other way around
    I'm buying a Symphony from a non-BOSE and putting it into my car equipped with the BOSE system, amp in the trunk and all.
    SIXFIVEOHphoto
    Feb 03 2007
    Parsippany
    HAHA sry, then u need to work the other way around, it could be done either way.
    Prey
    Feb 03 2007
    Parsippany
    here is the link, its at the end of the page.
    http://www.ibiblio.org/tkan/audi/radios/symphony.html
    Prey
    May 19 2007
    Bay Area
    And according to his site, they are the same unit, just programmed differently. Thanks so much for the info dude!
    SIXFIVEOHphoto
    Feb 03 2007
    Parsippany
    Quote Originally Posted by sixfiveoh View Post
    yup, you got it.
    Prey
