Results 1 to 15 of 15
Thread: b6 to b7? eh?
    Registered Member One Ring DarkS2K's Avatar
    Apr 14 2008
    Audi s4 b6, Honda s2000, Evo X
    Wood Dale, IL
    Lightbulb b6 to b7? eh?
    Hello everyone. I recently got an 2004 s4 b6 with some front end damage. The engine is perfect and runs great but things like the front bumper, head lights, hood, and both fenders all need to be replaced. Now I was wondering if these parts would fit from the b7? I mean if I switched out the b6 fenders, hood, lights, and bumper with the b7 ones. Would it work? Is the length and engine placement on the b7 same as the b6? Because if this would work, ill be all over it. XD
    Pics for your amusement
    Senior Member Three Rings guglielmo's Avatar
    Feb 02 2008
    Westchester, NY
    You will need to replace the doors, rear fenders and trunk to make it work.
    Some guy on audiworld in canada did it to an A4.
    Apr 14 2008
    Wood Dale, IL
    Re: You will need to replace the doors, rear fenders and trunk to make it work.
    Quote Originally Posted by guglielmo View Post
    So it would work? Can anyone confirm this? I don't want to order all the parts and find out there is a problem I tried searching around but all i get is that lltek kit heh.
    Veteran Member Three Rings Nogaro_PhiDelt's Avatar
    Sep 15 2007
    2000 Nogaro S4 (Stg 2)
    San Luis Obispo/Burlingame
    Re: b6 to b7? eh?
    wouldn't that look weird if you only did the front end? I might be wrong tho...
    2000 S4 (Stage 2)
    ->APR
    ->2B H&R Coil-over Program
    ->17" Flik Lex wheels
    ->ASP Tru-Dual 89mm Exhaust
    ->RS4 Clutch
    Veteran Member Four Rings FastB7S4's Avatar
    Mar 01 2008
    12 CC Lux Ltd, 11 Touareg, Mk3.5 Cabrio
    ChesCo, Lancaster, PA
    Re: b6 to b7? eh?
    Quote Originally Posted by Nogaro_PhiDelt View Post
    Well the more aggressive front end is what people like most about the B7 and the rear what they like least so it would be the best of both!
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Re: b6 to b7? eh?
    Wouldn't that look funny, aren't the creases between the fenders and doors going to be different?
    Apr 14 2008
    Wood Dale, IL
    Re: b6 to b7? eh?
    Quote Originally Posted by FastB7S4 View Post
    Yeah, Exactly. I love the aggressive look, plus the car would confuse the hell out of my neighbors hehehe
    If I don’t do the b6 to b7 conversion. I’ll definitely pick up the boser hood.
    Quote Originally Posted by B18b1ex View Post
    That’s what I thought at first until, I started comparing the two a little more closely
    The only thing that has me concerned is the length of the hood. Its a lot longer on the b7 and I have no idea about the latch due to it.
    Veteran Member Four Rings bsrpilot44's Avatar
    Feb 25 2007
    B7 S4
    So.Cal
    Re: b6 to b7? eh?
    Don't do it. If you want a new look for your front end your much better off going Oettinger, which is just pure hawtness!
    Apr 27 2004
    2018 GTS Cab, 2020 AMG A35, 2021 XC40 PLUS parking lift
    Re: b6 to b7? eh?
    I believe I know the guy who did it. I recall his post and do not think it was a straight forward job. If you want his phone number, PM me.
    Need a hotel in Ottawa? Try Albert@Bay or Best Western Plus Ottawa Downtown
    PM me for AZ discounts !
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Previous rides: B5 A4, B6 A4 Avant, B7 S4 Avant, B7 RS4, TTS, B8 A4, S3, 2019 Targa
    Apr 14 2008
    Wood Dale, IL
    Re: b6 to b7? eh?
    Quote Originally Posted by Stevelev View Post
    I don't think a phone number is really necessary heh. Maybe If he has a messenger or maybe email or something of that sort would work. I just need confirmation that this can be done with out too much custom work hah. from there on I think I should be able to figure it out
    Veteran Member Four Rings chunkyckn's Avatar
    Bay Area
    Re: b6 to b7? eh?
    You can find what you need here.
    http://www.lltek.com/hfltek_a4_8e_rs4look.htm
    Good luck if you decide to go with it, and rememeber to post pics.
    Apr 27 2004
    Re: b6 to b7? eh?
    Quote Originally Posted by DarkS2K View Post
    I can't seem to find his email, sorry.
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Apr 14 2008
    Wood Dale, IL
    Re: b6 to b7? eh?
    Just to keep every one upto date. After hours of comparing the two I have decided to try the conversion.
    After the car is up and running ill order all the parts
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Re: b6 to b7? eh?
    The B6 Cab front would be unique. I like the shorter overhang.
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Apr 14 2008
    Wood Dale, IL
    Re: b6 to b7? eh?
    Quote Originally Posted by S4J View Post
    That would be cool. But I think the b7 front would have a bit more of an awesome identity crisis effect lol
