Results 1 to 7 of 7
    Veteran Member Four Rings jbrown7815's Avatar
    Mar 12 2008
    Portales, NM
    Passenger Front Window will not go up auto anymore
    What is this cause of this? Regulator?
    Goes down fine.
    I searched, but with no good threads.
    Veteran Member Four Rings HP18's Avatar
    Jul 18 2004
    Orange County - CA
    Re: Passenger Front Window will not go up auto anymore
    mine has the same problem, sometimes it works and sometimes it doesn't.
    Mar 12 2008
    Portales, NM
    Not a huge deal, just mildy annoying. My old GTI did it for awhile also, then stopped.
    Jul 18 2004
    Orange County - CA
    yeah, gets annoying when you turn your car off and click auto up for the windows and that shit still stays open
    Mar 12 2008
    Portales, NM
    Quote Originally Posted by 1SickA4 View Post
    Mine auto has never worked when car is off.
    Makes it easier to adjust for a crack
    Active Member Three Rings 3thrd_a_4's Avatar
    Oct 15 2006
    03 BT A4/91 GTI 2.9VR6 S/C'd
    Roll the window all the way up or either all the way down (Can't remember which) and hold the button for a few seconds to reset it
    ReVO BT and a bunch of other stuff
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    Try This:
    put car in on position... hold the switch all the way up until window closes hold for 5 secs and then push the switch all the way down until window goes all the way and hold.
    make sure you "click" the switch both ways
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
