Results 1 to 26 of 26
    Established Member Two Rings ExCarpi's Avatar
    Apr 06 2008
    2005 A4 1.8T 6sp
    Minneapolis, MN
    Angry '05 with APR TIP HELP!
    Hey guys,
    I am new to the board and found my problem after doing some searching.
    I found out that the 04-05 model doesn't work very well with the APR TIP.
    My question is I bought the APR TIP from Ecodetuning.com and it does not work! What are your recommendations about what to do!?! Should I contact ecodetuing or APR? What TIP should I get instead? Or should I buy additional hoses, clamps, and T-fitting to rig the APR TIP?
    Please guys I need help!
    Plus the fact I am pissed that this the APR TIP does not work like it says on their website and am out a car until I get a new TIP! Considering they say right on their website, "All APR Motorsport Hoses include everything you need for complete installation, including fittings and clamps".
    Dec 06 2007
    Re: '05 with APR TIP HELP!
    contact APR!
    -Kirk
    BetaAlphaTau Member #58
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Neuspeed extreme.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Apr 06 2008
    2005 A4 1.8T 6sp
    Minneapolis, MN
    Yeah it looks like that or the Forge. I just don't want to waste $160 on something that I can't use!
    Veteran Member Four Rings Groove1797's Avatar
    Apr 08 2004
    Your mom on a unicycle
    Eating Cheese Curds
    Since the 05's have bi-xenons the neuspeed extreme fits like a tree into a pencil sharpener. You need a T fitting and elbow grease. It will fit but it's a bitch
    4Runner, Rs5 and Alfa Guilia QV
    Veteran Member Three Rings AudiAdi's Avatar
    Jul 06 2007
    2020 Toyota 4Runner TRD PRO || 2016 Honda Pilot Elite AWD
    Bellevue, WA
    Quote Originally Posted by Groove1797 View Post
    Yep... found out the hard way myself. Good luck!
    USP CLUB MEMBER #78
    2005 Audi A4 1.8T Quattro 6M K04 - GONE
    2010 Audi S4 S-Tronic ADS Lite
    Apr 06 2008
    2005 A4 1.8T 6sp
    Minneapolis, MN
    Guess that is the only good thing about not having the Xenons.
    Has anyone made the APR TIP work with different fittings? If so, I would like to hear what you did.
    Veteran Member Three Rings Shady Milkman's Avatar
    Jul 20 2004
    04 A4 QTM
    Morris Plains, NJ
    I have an 04 and ill be trying to put on a forge TIP this weekend
    -Jonathan
    04 1.8tqm
    Apr 06 2008
    2005 A4 1.8T 6sp
    Minneapolis, MN
    Well let me know how it goes. I am interested to find out what will fit.
    Apr 08 2004
    Eating Cheese Curds
    Quote Originally Posted by Shady Milkman View Post
    Forge makes a specific year with an extra o2 bung so install will a breeze
    Veteran Member Four Rings a4000's Avatar
    Nov 30 2004
    Pittsburgh
    All forge are 04-05....02-03 need to plug extra hole.
    '17 Audi S8 plus // DS1 // E40 // SRM TCU // SRM Flex // SRM Manifolds // SRM 3" Intakes // 034 HPFP // ARM Downpipes // Milltek Non-Res // Ibis // Black with Arras Red Stitching // Dynamic Package // Bang & Olufsen // Black Optics // Driver Assistance // Cold Weather // CETE ASC // 21x9 Ferrada FR8 // PS4S
    '19 Q7 3.0T Prestige // Audi Design Selection Murillo Brown // Luxury // B&O // Black Optics // Adaptive Chassis // Cold Weather // Tow // Night Vision
    Jul 06 2007
    Bellevue, WA
    Quote Originally Posted by ExCarpi View Post
    Like someone said earlier, you'll just need a T fitting to make up for the lack of an extra hole. The material of the APR hose is actually quite good if you can get it to fit!
    USP CLUB MEMBER #78
    Apr 06 2008
    2005 A4 1.8T 6sp
    Minneapolis, MN
    The main problem is one of the bigger hoses is really not long enough. It looks like I will have to go to the auto shop to buy a 90 degree fitting and some extra hose.
    The T-fitting I got does not fit the hose, it is really loose. I might have to buy a step down fitting for that.
    I just would rather return it for something that actually fits. Seeing the website says it includes all fasteners and equipement needed to install.
    Does anyone have suggestions about what clamps to use for the smaller hoses? Or should I go buy some more OEM style.
    Veteran Member Four Rings dubenvy's Avatar
    Oct 22 2006
    '14 A4 2.0tQ (wifey)
    Odenton
    I bought a samco fitting at Waterfest that looks like an "F" and it remedied the vacuum hose issue. With the fitting behind the Bi-Xenons, I just grabbed the TIP and squeezed it at the part where it was hitting the head light. The TIP will hold it's shape and fit better behind the housing.
    My other issue I had with this TIP is the N75 Bung is too long and the valve was popping out. I had to do alot of modifications with a dremel to allow it to sit better.
    USP CLUB MEMBER #41
    <<Insert Clever Signature Here>>
    Jul 06 2007
    Bellevue, WA
    Yeah... the APR advertising is disappointing, but they also cost almost half of others. Even with the extra hardware you'll have to purchase you're still spending less than you would with other TIP's. You can get the Neuspeed/Samco one for a direct fit, but again... they cost almost twice as much as the APR.
    USP CLUB MEMBER #78
    Apr 08 2004
    Eating Cheese Curds
    ^ the apr also has the internal wire wrap for extra collapse resistance.... which is nice
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    I had the same APR TIP fitment issues on my '04 A4 as well. I posted a number of threads about it, you should have searched first!
    I just went with the Forge instead and it fits very well. Some people have said they needed a little trimming done at the bottom of the pipe that connects to the mouth of the turbo, it's fairly long. Screw APR, no matter what they say it doesn't fit the '04-'05 A4 very well, if even at all. Mine kept slipping off every day or so until I finally replaced it.
    Good Luck, Forge offers a great product for about the same price!
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Feb 17 2005
    Sarasota, FL
    If you have an 02 bung/sensor in your TIP, your car has a serious problem
    Feb 17 2005
    Sarasota, FL
    For the OP, you could have searched and found out it was made for the earlier models, you could also search and find out it works perfectly fine on 04-05's with about 10 bucks worth of parts from the hardware store. No reason to freak out ...
    Veteran Member Four Rings jrau13's Avatar
    Mar 12 2006
    02 Mercedes ML, 04 Avant 1.8t
    Costa Mesa
    I bought the Forge TIP that LampyB had recommended and with great results. It wasn't an easy install but in the end it was all good, no trimming and good to go
    I'll keep my money,
    My Guns, My Freedom,
    & you can keep the CHANGE
    Veteran Member Three Rings RED1.8T's Avatar
    Jan 19 2007
    Columbus, Oh
    APR = garbage
    sorry to all APR fans...
    Dec 25 2004
    Earth
    I've owned, R&R'd and run all 3! I had the APR...sold it.
    Bought the Forge. It installed, and fit much better than the APR.
    Now i have the Neuspeed.
    IMO, the Forge TIP was the best for the cash. However its only for the K03/K04.
    Apr 06 2008
    2005 A4 1.8T 6sp
    Minneapolis, MN
    Just want to let you guys know. I contacted APR and sent them pictures or the problem.
    They contact me back saying that it does not fit the way they want to on the 2005 A4. They are going to look into fixing the problem and refunded my money.
    Now it looks to be between Forge and Neuspeed!?!
    Any thoughts?
    Jun 30 2007
    Raleigh, NC
    custom.
    my tip ran me about 75 bucks
    granted that's a 3" for a GTRS... but i'm sure you could make something similar.
    STFA for custom TIP and a few threads should come up.
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Mar 12 2006
    Costa Mesa
    Any thoughts?
    That's an easy choice...are you planning on going to a larger turbo or not? If not then the Forge and if SO then the Neuspeed is your choice
    I'll keep my money,
    Mar 12 2006
    Costa Mesa
    Oh and the price is a big difference
    I'll keep my money,
