Results 1 to 17 of 17
    Senior Member Three Rings Murf's Avatar
    May 19 2007
    02 Audi A4 1.8t quattro
    New Jersey
    CV Boot/Axel help
    So today i was doing some suspension work and noticed grease all over my wheel and my shocks. I did some searching it doesn't look like it is ripped or teared like some of the pictures in the other threads.. The grease is just coming out from the very tip of the boot. I have also been noticing the clunking noise that other people were hearing. My question is how long can i drive with it like this? and what exactly do i need to fix it? Also if someone could direct me where to purchase these parts i would really appreciate it.
    2002 A4 1.8t 5speed
    STaSIS StreetSports | 19" Privat Reserv's | Pioneer AVIC D3 | Decorsa Street Exhaust | Boosted Tech CAI | | JHM Short Shift | Forge Splitter
    Senior Member Two Rings abradley's Avatar
    Mar 12 2007
    02 A4 3.0 Quattro
    Virginia Beach
    Re: CV Boot/Axel help
    try to take the boot off and get new grease to fill what came out. if you dont notice a difference with the sound, check out raxles.com i'm sure someone else will chime in on what exactly you might need. could be a bearing or axle. i just had to replace both and noticed the same thing you have going on. no tear in the boot but saw grease all around it when i was adjusting my suspension. took it to the dealer and they told me what was wrong and quoted me like $900. crazy shit. check out that site if you need parts though
    Veteran Member Three Rings quattrotman's Avatar
    Sep 26 2006
    You will eventually need to replace the boot and repack with grease but if you're hearing clunking it might be too late. You can drive with it like that actually for a while but it will keep losing grease and eventually dry up which will accelerate the wear of the joint dramatically. Theyh have been known to seize but that itsn't common. You should do it sooner than later. You might be better off just getting new axles and re/re them. Labour, from what I remember, was quite a bit and $900 doesn't sound ridiculous from a dealer.
    Dec 06 2007
    i can get 2 new axles installed for like $400!
    -Kirk
    BetaAlphaTau Member #58
    May 19 2007
    New Jersey
    Actually, i'm not sure what i am hearing is the knocking sound that people in the other threads were talking about. What i am hearing is when i turn the steering wheel all the way, there is a knocking noise which could just be the wheels hitting the wheel wells since I'm lowered. But is there any way to just fill the boot with grease and seal it since it's not torn?
    2002 A4 1.8t 5speed
    Veteran Member Four Rings ultra's Avatar
    Apr 12 2007
    13 Allroad
    San Antonio,TX
    Quote Originally Posted by AudiA4Turbo22 View Post
    pm sent
    Eurocode
    2013 Allroad Volcano Red, Eurocode goodies
    2018 SQ5 Florett Silver S-Sport package
    Veteran Member Four Rings A4Shizl's Avatar
    Jun 11 2004
    2003 Audi 1.8T, 2005 Honda
    Inland Empire
    Quote Originally Posted by ultrasporty View Post
    pm sent
    x2
    Dec 06 2007
    Replied x2!
    -Kirk
    May 19 2007
    New Jersey
    Bump...anyone know if i can just refill the cv boot and seal it since it isn't torn?
    2002 A4 1.8t 5speed
    Dec 06 2007
    try it and if it doesn't work then change it! they last awhile with no grease! anyone have a rattle coming from both sides of the front when driving? it's driving me nuts!
    -Kirk
    Veteran Member Four Rings PETARDED's Avatar
    Dec 19 2005
    Arlington, Va
    I have all kinds of wierd pops and clunks coming from the front end of my car, when I took it to the shop they said on three different occasions that they could not find anything. Im assuming that they guys at the dealership could locate a problem like this. But I am now having this weird rattling from the front end, or underneath that sounds like something hitting my exhaust, also its been coming and going at freeway speeds, what it is I have no clue. But between the $1100 for a fuel pump, and now this, I can officially say that this is my last Audi, I felt like I was making a step up when I bought it, but this car has been a nightmare; bad service regarding coil packs...etc...Im done!
    Originally posted by Underground
    You guys are just dead inside
    Formerly 04Red_Rocket
    No Better Friend, No Worse Enemy.
    Somebody please take this piece of shit off my hands.
    Dec 06 2007
    ^^haha! exact problems i'm having the clunking only happens in the morning! the rattles are loud as hell at freeway speeds! it's ur CV joints it needs new axles no biggy about $400 for 2 of them!
    -Kirk
    Dec 19 2005
    Arlington, Va
    Is that installed and everything? That seems rather low!
    Dec 06 2007
    installed and everything catch is u have to trade them for ur axle, like they take ur busted one!
    -Kirk
    Dec 19 2005
    Arlington, Va
    Who is this? How do I find them, I literally had the car taken to the dealer three times, can I go back to them, since I kept my reciepts and be like, "Look this is what is wrong, you guys failed to fix it, three times."? LOL!
    Dec 06 2007
    ^^ u can! shove it in there face! first take it to a good shop have them right down that this is what is wrong then shove it in their face and tell them to fix it!
    -Kirk
    Dec 19 2005
    Arlington, Va
    Hahahah, what is the possibility that there is something else wrong, I have noticed that the tires on the front right wear differently, as in wear uber fast....
