Results 1 to 13 of 13
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    doing my JHM shifter install tomorrow, what do i need to know
    any tips, tricks, etc, appreciated! [O_O]
    Veteran Member Three Rings drexplode's Avatar
    Jul 19 2007
    2016 M3 - maximum hooligan
    Michigan
    Re: doing my JHM shifter install tomorrow, what do i need to know
    lots of patience, and an angle finder at the very end!
    you will love it, and if it takes you hours...it is definitely worth it!
    "A turbo boost gauge the size of a fat spaniels face! - Jeremy Clarkson
    Dec 05 2006
    So. Cal.
    Shift the car into 2nd gear when you reinstall the bolts. It'll make it easier to line up the bolts. Don't tighten it down in 2nd, just get the bolts into the holes.
    Mar 09 2005
    Santa Clara, CA
    thanks guys, hopefully i dont F up!
    Senior Member Two Rings psiaddict's Avatar
    Feb 26 2008
    Milwaukee, Wisconsin
    Go here, watch the video for you car install. Not too bad to do.
    http://jhmotorsports.com/videos/
    Mar 19 2008
    Tulsa, OK
    Make sure the reverse notch is on the passenger side and make sure the shifter will go into all the gears, i had to move mine up a notch to fit my B5.
    Veteran Member Two Rings
    Mar 07 2005
    Oregon
    One thing of note is that the video which shows the use of the angle gauge is used on an older shifter that has a straight shaft. Your shaft has a bend in it....
    Mar 09 2005
    Santa Clara, CA
    Quote Originally Posted by Randy M View Post
    does this mean no angle gauge? or use it on the straight part
    Mar 07 2005
    Oregon
    I gues if you can find an angle gauge that is small enough to work on the straight part but the one I had was too big.
    Mar 07 2005
    Oregon
    Oh yeah you're gonna need to get a hose clamp to keep your shift knob on. Sorry I forgot to tell you...
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    I have not installed mine yet but just watching the install videos on their site gave me an idea on how difficult it is. Should probably say how easy it is. Just watch those and read that one document if you have the extra short version.
    Mar 09 2005
    Santa Clara, CA
    hose clamp?
    Mar 07 2005
    Oregon
    Yeah a hose clamp is included in the JHM kit. You have to bust off the stock clamp that holds the shift knob to the shaft which is why it's on my car now. Sorry about that.
