Results 1 to 7 of 7
    Established Member Two Rings lask8ter134's Avatar
    Sep 07 2007
    Audi A4 B7
    Whittier,CA
    worried about messing up the clutch!!
    i have a audi b7 tiptronic, and i always downshift and brake when i come to a stop or red light. does down shifting wear out the clutch? because i know audi uses software to prevent damage to ur tranny but i always use tiptronic n im afraid that im going to wear out my clutch if i down shift coming to a quick stop.
    Audi A4 Non-Sline 2.0T Fwd Cvt Evo Ms Intake/Apr 91/100/Miltek 200 Cell Cat/Magnaflow Exhaust/Vogtland 35mm springs, Koni Sport Shocks/R8's Replicas w Toyo Proxy 4's/Hawk Ceramic Pads/Front Filler Plate/30% tint/Garmin 760 GPS
    Apr 06 2007
    Arcadia, CA
    Re: worried about messing up the clutch!!
    I don't think tiptronic has a clutch, but downshift to brake is not good for your transmission in general. It's better just to use your brake only; that's what brake is for!
    07 B7 A4 Quattro Manual Sline.
    APR Software | Ecodetuning Testpipe | Milltek Exhaust
    RS4 Rear Sway Bar | ECS Snub Mount | AWE Boost Gauge
    Forge DV | PSS9 Coilover | Hartmann RS4 Replica with Falken 452
    Oct 12 2005
    B7 A4 2.0T 6speed Sline
    San Francisco
    I like downshifting in my Manual, but it's true Brakes are cheaper to replace than a clutch, in an Tip, just use a brake, b/c in your situation Brakes are DEF cheaper than a tip tranny.
    Mod lists are weird
    Veteran Member Three Rings greene08's Avatar
    Mar 29 2008
    2023 Audi SQ5, 2024 Tesla Model S Plaid, 2022 Kymco People S150i
    Costa Mesa, CA
    Automatic transmissions actually do, by design, provide braking aid when slowing down during a gradual (normal) stop. They do not aid when you brake hard or in an emergency.
    Your automatic transmission (Tiptronic) does not have a traditional "clutch" although it can wear out just like any other transmission does over time. Down-shifting in an automatic, equipped with a clutch-less shifting function, will not hurt your transmission. The transmission's computer is designed to prevent you from down-shifting if it is not appropriate.
    A manual transmission car uses two plates, and friction to create a positive connection. If you "ride" the clutch and don't let the plates fully engage (i.e. with improper UP OR DOWN shifting) you will destroy the clutch in no time. An automatic transmission, while using friction as well to make a positive connection is doing so with computer controlled precision every time so you need not worry.
    Either way, being kind to your car will generally mean it is kind back to you. The more you beat it, the more it will beat you (in your pocket at least).
    On that note, don't be afraid to have fun. The Tiptronic feature of the Audi's is great fun when you use it... so use it. That is one of the reasons it is there. Don't do a power launch though; that will ruin your tranny faster than you can burn toast with a blow torch.
    Lover of all things motorsport, powersport, sport.
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    ROFLMAO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    In before the lock!
    2006 Audi A4 2.0T Quattro 6MT S-line
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Yeah just keep it in Tip mode and use the brake and it will downshift for you and have fun shifting up!
    Mar 29 2008
    Costa Mesa, CA
    Quote Originally Posted by INTEGRATION View Post
    In before the lock!
    Que?
